Hi, mates! Need help here:
I've got two different versions of the same material, encoded in differrent software/hardware/parameters and time in the past. Don't have original anymore.
Well, now I'm trying to create a third version w/ video from Version1 and audio from Version2. Result: audio synching issue!
See attached the properties of the two files.
Thanks in advance!!!
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
How is it out of sync ? Constant offset? Progressively worsening ? In and out of sync ?
In theory you should be able to use mkvtoolnix, load the videos, checkmark streams you want, uncheckmark streams that you don't want
But version2 is variable frame rate according to mediainfo - that might give you problems. You might have to play with timecodes or check the video frames and audio duration more closely -
I think you're right: variable frame rate of Version2 is the problem. I have never seen it! All methods I tried gave me out-of-synch result. And it's not time shift or duration issues.
How do I deal w/ timecodes?
Audio exchange on an AVI
By alih786 in forum EditingReplies: 1Last Post: 14th Nov 2019, 13:44 -
How can I combine ripped DVD material with HD material to make a new Blu?
By swarez in forum MacReplies: 4Last Post: 9th Jul 2018, 11:17 -
How to exchange the audio track in a .wmv movie file?
By Potti in forum Newbie / General discussionsReplies: 10Last Post: 29th Apr 2017, 14:13 -
Newbie looking for video editing reading material
By Downtime_1 in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2016, 13:29 -
How camcorder save full HD video material?
By Stile in forum Newbie / General discussionsReplies: 7Last Post: 14th May 2016, 16:52
