If I want to record an online video stream with audio from a browser...
Must the window or tab with the movie display in full screen mode?
While it’s recording, can I surf the web in other tabs or windows? Or does the movie have to remain front and center on the display until its conclusion?
Does my display have to remain on for the duration of the recording, or can it go blank to save energy and conserve the backlight life?
I have an underpowered old tablet with Celeron and 4 GB RAM. Is this sufficient to get a good result? OBS’s wizard recommended very low resolution output for my hardware, but I want to try for HD.
Can I damage my low end Intel video card by making it try to do too much, i.e., save as HD?
I still don’t know what program I will use. Have been trying OBS Studio but find interface very confusing.
Thanks for any help.
Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
okay i may not have perfect answer for you but i am going to try anyway since no one has replied yet
so screen recordings arent always perfect.
i am guessing you want to surf web while you screen record.
so yes you can do that all you need to do is create a separate workspace
i am on windows 10 so if you go to task view and then you can create second desktop
guide here: https://www.cnet.com/how-to/how-to-use-multiple-desktops-in-windows-10/
now when you are in second desktop you can play in full screen and start screen recording
after you start screen recording press WIN+CTRL+LEFT on windows it should shift you to your first Desktop.
so now you can surf web while you screen record.
when you screen record make sure to disable the sound from other programs so sound from other programs do not interfere with your recording audio
if you press WIN+G it should open Xbox Game Bar
it has this option where you can change the sound of individual program while you screen record. irrc other screen recorders have this option too
screen recordings usually result in very large sized video files.
to capture streaming video also try Tubedigger.
Edit: from where do you want to screen record? -
Thanks for the reply. Well, my old tablet uses Windows 7. Can I still create a second desktop?
I want to record from a site that makes downloading impossible.
What about the screen blanking question? Can I let my screen go black while it's recording to preserve backlight life? Or will that mean the recording will go black?
Since my hardware is pretty inadequate, might it be a better idea to use a free online recording service?
Do any smudges on my display show up in the video? Should I clean the display first? (You can tell I've never done this before).
Thanks for the Tubedigger recommendation. I will check it out. -
https://www.videohelp.com/software/sections/desktop-screen-capture
currently window 7 doesnt has any option to create "second desktop" but you can achieve that with some third party software.
https://www.howtogeek.com/195962/unlock-virtual-desktops-on-windows-7-or-8-with-this-microsoft-tool/ - i have not personally tried that so if it doesnt work for you try some other similar software.
screen recordings are not perfect and usually have a large file size it. its easier to download rather than screen record its just very time consuming and isnt real
if you are looking for a way to download from Netflix you can use AnyStream. -
Thanks again. My computer won't go to sleep or hibernate, I have set it to not do that. But I have a little applet that can blank the screen. I mean, I don't want to have to watch the vid while it records, if I have other things to do.
When I say free online screen recorder, I mean something like this:
https://www.apowersoft.com/free-online-screen-recorder
I agree if would be much better to download it, if I can find a way.
Thanks again for your ideas.
How to correct screen recording display PC to avoid flickering over video?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 24th May 2020, 14:42 -
Trying to screen record streaming video w/ movavi...audio sync issues
By Benny in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2020, 16:14 -
General questions about video screen capture pay software
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 25th Dec 2016, 00:45 -
Streaming video and recording at the same time?
By SteveF22 in forum Video Streaming DownloadingReplies: 1Last Post: 28th Jul 2016, 06:16 -
Artifacts in Screen Capture of Streaming Video
By malrey in forum CapturingReplies: 4Last Post: 12th Jun 2016, 13:39
