You also have to add a delay or advance at the start to sync the audio. I thought that was obvious.
Results 91 to 96 of 96
No, the start frame is ther same, and, while there was 6sec async added along movie, it's only 2sec, at the end, of a 1,30 hour movie. Not a delay from start to end.
Then you need to adjust it more. Don't be surprised if after you get the start and end perfect there's a difference in the middle. Unless the two audio tracks came from the same source (ie, same DVD, same BD) it's often the case that the cuts are different.
Just to tahnk you Jagabo, i won't ask anymore questions, it's bothering...
Interlacing was hard to understand clearly, FPS are another thing that make things hard !!!
Bonnes vacances.
Audio doesn't have a frame rate. It has a running time. And for an A/V file it has a starting time relative to the video. It doesn't need to start at the same time as the video, end at the same time as the video, or have the same length as the video. You can use video frame rates to get a hint at what might have been done to the audio but that's not definitive. Movie releases in different countries are often different cuts of the movie and different studio/distributor logos at the start. If one is from an over-the-air broadcast it may have been sped up or cut to fit the broadcast window. Someone may have cut out ads, and with a fade-to-black between the program and ads, one can't say exactly where the show ends and the ad starts. That can often result in a few seconds difference over an entire movie.
Happy new year everybody,
many thanks for help i received on this topic...
I upload some interlaced files to be available some time for people that want to learn deinterlacing.
That's all.
https://drive.google.com/drive/folders/1Ow6awXzIykCWsXmdwbNGtXYINnOkHWXG?usp=sharing
Resizing after deinterlace PAL DVD w/ QTGMC
By rilopes64 in forum DVD RippingReplies: 11Last Post: 3rd Dec 2019, 11:01 -
newbie to AVISynth & VirtualDub-need help with IVTC & deinterlace via QTGMC
By clashradio in forum Capturing and VCRReplies: 79Last Post: 14th Nov 2018, 21:05 -
Which DVD to use? PAL or NTSC, and which Deinterlace/Detelecine options?
By U2Joshua in forum Video ConversionReplies: 17Last Post: 16th Jan 2017, 20:59 -
Best DVD source for ripping? PAL or NTSC? deinterlace/detelecine options?
By U2Joshua in forum Newbie / General discussionsReplies: 2Last Post: 12th Dec 2016, 21:04 -
Smart render. Lagarith > Vegas(edit) > Lagarith.
By ValentineStone in forum Video ConversionReplies: 11Last Post: 5th Oct 2016, 14:31
