Hello,
Recently i remembered a movie, found the DVD (new) and buyed it knowing it was poor quality.PLZ download this videos (in .7z) to look at it if you want help with deinterlacing and FPS change.
https://drive.google.com/file/d/1-89QCYzT2YP2nnFk-kVn98A1Akv5bODj/view?usp=sharing
https://fr.shopping.rakuten.com/offer?action=desc&aid=3906253293&productid=1024631
Yesterday i buyed it twice, first is dated 2002-9 but this is 2006-5. Hopeless it's a better one.
https://fr.shopping.rakuten.com/offer?action=desc&aid=5470558908&productid=47573584
Also i found a recent (2019-9) rerelease but is NTSC and not cheap (25$ + 20$ shipping fees).Who knows if the master is the same or of any better quality !?!
https://www.allmovie.com/movie/3-am-v239363/releases
https://www.moviesunlimited.com/3-am-showtime-3-a-m/810017881093
I also downloaded the movie from YT in VO, if i change framerate to 23.976 it syncs perfectly (Toolnix 960/1001).
https://youtu.be/K1k72YGNM0c
Okay,
before watching it i want to give the best deinterlacing method as possible, that's why i need help. This DVD is PAL, i must also change FPS to recover original playtime (88>92).
Imdb :
Taxis pour cible (2001)
3 A.M. (original title)
1h 32min
88 min | 92 min (DVD) = but, PAL-DVD @ 1:27:45s - so 88 not 92, what is good ?-----------Media Info :
PAL
25,000 Im/s
720 pixels
576 pixels
Variable bit rate
Entrelacé ligne du haut d'abord (top field)
YUV
4:2:0
GOP Open
BT.601 PAL
BT.470 B/G
AC-3
2 canaux
Constant
448 kb/s
48,0 kHz
I found HandBrake gives the best with Decomb+Eedid2 (no autodetect). But from the DVD files only, strangely if i load the Lagarith with FPS changed to 23.976 by VirtualDub2, it works not the same. At all.
Now i have to find the way to use VirtualDub2 for perfectly deinterlace the uncompressed AVI.
MeGui :
AUDIO 25 to 23.976 .flac (DVD AC-3 demuxed stream, _delay 0) ?_? Pitch Correction - it's good ?_?
VirtualDub2 settings :
CROP (camera has unstable frame, from time to time along the movie more or less CROP should be done, strange but not a big thing).
LAGARITH (prevent upsampling, no pixel change).
AUDIO from MeGui.
NEED DEINTERLACING THIS STUFF
Handbrake :
AVI uncompressed to h265
I finally found something that should do the trick, but i have never used AviSynth before. Am i on the good wy ?
AviSynthPlus 3.6.1
Decomb 5.2.4
EEDI2 0.9.2
EEDI3 v0.9.2.1 (not the same think, i'll try to see)
Another but i'm note quiet sure :
nnedi3 0.9.4 (intra-field thing)
I wait some reviews and will respond as quick as possible. I'm French, hoping to be understandable at my level of English.![]()
Results 1 to 30 of 96
There are many ways to perform NTSC/PAL conversions so you need to provide a sample from the DVD to know the best way to restore the original. An easy way to do this is to use DgIndex (included with the DgMpegDec package for AviSynth). Open one of the VOB files from the DVD, mark-in, mark-out, File -> Save Project and Demux Video. Upload the resulting m2v file. Be sure to include a medium speed panning shot.
You will probably need to use AviSynth for the best results. -
If that sample at the top is from the DVD, then it's almost all progressive with interlacing sometimes at scene changes. That can be fixed by deinterlacing when it happens and no other times. This thing should definitely NOT be deinterlaced with Yadif or any other deinterlacer that deinterlaces everything. There are several ways to deinterlace just what needs deinterlacing in AviSynth.
Vinverse()
is one way, although I might do it using QTGMC when needed:
Mpeg2Source("Test.d2v")
tdeintted = QTGMC(FPSDivisor=2)
tfm(clip2=tdeintted)
If you want to slow it to film speed you add an AssumeFPS(23.976) to the script and slow the audio to match. -
Sorry, I somehow missed that.
Yes, the video is mostly progressive frames with a few interlaced frames at some shot changes. If you've never used AviSynth before I would suggest you just use TFM() (without the clip2=QTGMC(...)) -- just because QTGMC() is very hard to get set up (you have to download and install several third party support filters). Even Handbrake's Yadif deinterlacing is adequate for the minor amount of comb artifacts in the movie. -
I say movie, not the technical video term referring to 24p, but to the film title (3 a.m ; Taxis pour cible). I must deinterlace someway.
That's what i tried, it works well, perhaps even better audio with pitch correction. But IVCT doesn't work at all it's PAL, download the video to look at interlace ( i pointed frame to look at, it's 16MO direct stream copy from DVD).
https://drive.google.com/file/d/1VOA-_ECUucY8E5t6O2pe4al9lcdPCJwG/view?usp=sharing
I tried all in AviDemux, only Yadif (not good enough, like Handbrake and VDub) and Libavdec (Linear interpolation) work.
Hey, the sample is available since first post at the first line of the topic !! It's the 16MO video i just reuploaded, frames 164 and 192 are good exemple about what deinterlacer should work on. First post (93MO) even contains divx version to look at audio sync to 23.976 and pitch correction, and info in .txt.
AviSynth+ actually, and that's why i need help, i found decomb and Eedi2 (or 3) in VDub external filters page
http://avisynth.nl/index.php/External_filters#Deinterlacing
Direct stream copy from VOB, yes (untouched).
Handbrake perhaps give best result if i deactivate detection mode, not clear (i should deinterlace before recode it anyway, better).
That's why i'm here, learn the best way to deinterlace that DVD :
Megui can demux streams (.d2v), it says "partially interlaced"
VirtualDub2 indexes .m2v or .vob's (.midx).
HELP me with Avisynth+
YES, it is direct stream from DVD as .mpg files (19s & 1min), and info in text file says that, and also to look at frames 164+192 to quick access best touched frames !!
NO, yadif from Handbrake is less good than Decomb with this source, i tested (Eedi2 is good to add).
Thanks guys, i gone to sleep just after posting first timeLast edited by KlemNT; 11th Nov 2020 at 21:38. Reason: google drive linked to video preview, now it's downloadable in archive 7z
No, have to do that It's Avisynth+ right ?!
About QTGMC, i was interested about that script
http://avisynth.nl/index.php/QTGMC
https://forum.doom9.org/showthread.php?t=156028
I'm new to AviSynth, understood QTGMC is a script (not a plugin, like TempGaussMC also), should i install +plus+ version of AVS (Improved still image support and TimeStretch) ?!https://avs-plus.net
Thanks to you and manono.
My goal is to export in Lagarith, 23.976 (MeGui audio slowdown works perfectly, and has pitch correction that is better than original i think).Last edited by KlemNT; 12th Nov 2020 at 00:55.
Can't you find a widescreen version of the movie? You prefer 4x3 ?
Ther is no 16-9, it certainly was shot as this, even the newer rerelease (2019-9) CBS DVD is 1.33:1, and i don't know if it's a better quality or a "copy" :
It's official Sundance's selection Lee Davis movie (Spike Lee's friend)This marks the third incarnation of “3 AM” at the Sundance Film Festival (invited twice previous into the writers lab for the script). After viewing the final product, maybe the Utah folks would agree to a fourth try?
“3 AM” is a disjointed story of three cab drivers in the big city of New York: Hershey (Danny Glover), a failed basketball player who can not seem to get a hold on his emotions; Rasha (Sergej Trifunovic), an immigrant from Bosnia who is in love with a bath house girl (a side story that leads directly to a dead end); and Salgado (Michelle Rodriguez), an angry-at-the-world, completely insane Latina who has delusions involving evil spirits. There is also George (Pam Grier) who dates Hershey, but since she has about twelve minutes of screen time, and nothing to do during that precious time, she is not even worth summarizing.
Unfortunately, there is no chemistry between Glover and Grier and the duo of Salgado and Rasha should share a jail cell. Since this film is trying to be a “character study” ala “Boogie Nights” or “Magnolia” the audience must, in any way, be able to relate with some, if not all, of the characters being studied. Sadly, only prisoners or lawyers possess the patience to understand the illogical mindset of these detestable people.
“3 AM” meanders from story to story with no real purpose or focus. There is also a side story of a “serial cab killer” which goes nowhere and is simply there to fill the blood and violence quota. On the unnecessary topic, the out-of-place cameos by Spike Lee, Walt Frasier and Pepa (the other half of “Salt”) really bring the viewer out of the world that the film is trying to create. About the only success involved with this film is making the audience unanimously agree to set off a bomb on the entire city and hope the innocent rats and roaches survive.
[Attachment 55804 - Click to enlarge]
[Attachment 55805 - Click to enlarge]
What this rerelease offers ???????
[Attachment 55806 - Click to enlarge]Last edited by KlemNT; 12th Nov 2020 at 01:52.
So,
source is the DVD5-PAL (DvdShrink movie only, no compression nor menus). DVD folder @ 3,40 Go (3 659 325 440 octets).
MeGui demuxed streams :
AC3 - 281 Mo (294 839 552 octets)
M2V - 3,06 Go (3 291 370 780 octets)
MeGui can do the audio 23.976 (pitch correction)
VirtualDub should :
Deinterlace the video with the help of AviSynth(+),
Change FPS to 23.976
Crop - left/10 right/6 top/2 bottom/2
Output to Lagarith (source colorspace : YUV420 - BT.601)
What i don't know is, if VirtualDub is configured (Lagarith : multithreaded, prevent upsampling when decoding, no change colrspace / crop 10-6-2-2 / change framerate 23.976), Avisynth knows it, or all must be in a script (even Lagarith options) ?
A+
EDIT = i don't ccare about procesing time, i just want the better output ( i7 9700 - GTX1660 )8 Cores
8 Threads
II :
Shoul i first create a untouched Lagarith .avi ? Or process directly the .m2v+.d2v.
III :So that's AVS 2.6.0 MT by SEt (not the + version) ?!
IV :
I'd like to make a "Source Match / Lossless" if i can.
QTGMC( Preset=XXXX, SourceMatch=3, Sharpness=XXX, TR2=X, Lossless=2 ) # Best quality, slowest, very minor residual combing
V :
Why all forums on the internet have a tiny window for posting ?
Hey, i found a window extension button right up in the corner
So i found that the mouse whell moves page down or up when reaching encd of edit window
VI :
I'm trying StaxRip (in VirtualBox), i demuxed (the .mpg) FF and eac3, first add delay and no video demux, second has a little smaller file size (no delay) and video demux. Important (filesize, delay) ?
VII :
I should do it @ 24 FPS MeGui has the audio option for 24p
VIII :
"Pitch correction" sounds good, if i omit the option when converting FPS from origial PAL 25 to 23.976 (or 24) appears a sort of echo ! Am i right ? The file i uploaded at first thread (my first words) contain 3 audio !!! Check if you want.Last edited by KlemNT; 12th Nov 2020 at 07:10.
So, i should put all those parameters in the AVS script :
1 - Deinterlace QTGMC (noob)
2 - Crop L-10 R-6 T-2 B-2
3 - Change FPS 25 to 24
4 - Output Lagarith, and his options (multithreaded, prevent upsampling when decoding, no change colorspace)
10 - Finally with the result file i do what i want.
What i retain about QTGMC (i won't hide i nedd help) :
MVTools2
Estimation and compensation of objects motion in video clips.
May be used for strong temporal denoising, advanced framerate conversions.
Nnedi3
An intra-field only deinterlacer. It takes in a frame, throws away one field, and then interpolates the missing pixels using only information from the kept field.
Nnedi2 with improved predictor neural network architecture and local neighborhood pre-processing.
Zs_RF_Shared.avsi
TDeint
Bi-directionally, motion adaptive, sharp deinterlacer.
Can adaptively choose between using per-field and per-pixel motion adaptivity, and can use cubic interpolation, kernel interpolation (with temporal direction switching), or one of two forms of modified ELA interpolation which help to reduce "jaggy" edges in moving areas where interpolation must be used. -
Yes but when i output the video to Lagrith (change FPS, CROP) before using Handbrake, Decomb+Eedi2 doesn't work as well as with the DVD-VOB source. In fact it feels like Yadif with the DVD source, that doesn't gives good result.
Is that a colorspace probleme, i'l try different settings to Lagarith (upsample). -
Here's what I came up with:
Code:a = LWlibavAudioSource("3AM - DVD-PAL (1min).mpg") v = Mpeg2Source("3AM - DVD-PAL (1min).d2v", CPU2="ooooxx", Info=3) AudioDub(a,v) TFM() Crop(10,2,-6,-2) QTGMC(InputType=2) Spline36Resize(768,height) AssumeFPS(24000, 1001, sync_audio=false) ConvertAudioToFloat().TimeStretch(rate=(24000.0/1001.0/25.0*100.0)).ConvertAudioTo16Bit() prefetch(8)
I encoded that with ffmpeg by dragging and dropping the AVS script onto this batch file:
Code:Start /b /low "ffmpeg" "G:\program files\ffmpeg64\bin\ffmpeg.exe" -y -benchmark -init_hw_device qsv=hw -filter_hw_device hw -v verbose ^ -i %1 ^ -c:v libx264 -preset slow -crf 18 -g 50 ^ -profile:v high -level:v 4.2 -adaptive_b 1 -rdo 1 -g 50 -colorspace smpte170m -color_range tv ^ -acodec aac ^ "%~dpn1.avc.mp4"
Oh là là,
it's way better that what Handbrake can do, a thousand time better.
Why is this 768x572 lol ? Staxrip sayed that also, it's about aspect ratio, or that comes from FF !? Oops no, the script (edit)!!
That's good, for my first project i learn something to transcode a DVD to full quality, next i learn what to do with Resident Evil PSX intro's (i used jpsxdec, to full RGB>Lagarit after). Another thing i will do in video edit, is the real 3D video at the beginning of Silent Hill 4 (30 FPS maxi) i'l record.
Well, i'm back when i know how i can use that stuff (the script).Last edited by KlemNT; 12th Nov 2020 at 08:59.
What you have is an ITU cap where the 4:3 image is in a 704x576 portion of the 720x576 frame. The appropriate way to convert that to a 4:3 frame is to crop the width to 704x576 then stretch that to 768x576 (or any other 4:3 frame size). Your cropping removed 16 pixels off the width but it also removed 4 off the height. To maintain the correct aspect ratio requires resizing to 768x572.
Regarding QTGMC, yes, it's a script not a dll. But it requires several other 3rd part filters.
http://avisynth.nl/index.php/QTGMC#Core_Plugins_and_Scripts
And some of those require other third party filters. Then, depending on what QTGMC settings you use you may need several of the optional 3rd party filters:
http://avisynth.nl/index.php/QTGMC#Optional_Plugins
And some of them may require other 3rd party filters as well!
Since they are all made by different people, and many are being updated often, it can be hard to get compatible versions of everything you need. That is why I originally suggested using TFM without QTGMC as an option. -
Good advise, at least i've read the QTGMC page and it gave me an idea about it.
Crop this movie is not entirely possible, some parts (less) need more crop at left, i don't want delete image and that not so distracting. Perhaps we need a better master (or a BRD lol) :
Crop1+Crop2
[Attachment 55810 - Click to enlarge]
[Attachment 55811 - Click to enlarge]
Handbrake cant Decomb any .avi VirtualDub outputs (Lagarith : same as input, RGB24 // Uncompressd RGB : sames) 25 fps nor changed framerate, you can notice some very little difference between input color space and RGB24 output (need fullscreen image) :
Lagarith_input colorspace - Lagarith_RGB24
[Attachment 55812 - Click to enlarge]
[Attachment 55813 - Click to enlarge]
Ucompressed_input colorspace - Ucompressed_RGB24
[Attachment 55814 - Click to enlarge]
[Attachment 55815 - Click to enlarge]
DVD_decomb-eedi - DVD_decomb-eedi+autoetect
[Attachment 55816 - Click to enlarge]
[Attachment 55817 - Click to enlarge]Last edited by KlemNT; 12th Nov 2020 at 10:50.
Many thanks, that helps.
About stretching, i always keep as the same as original as possible, i compared and the face of the driver is larger. You're welcome.
DVD VS STRETCH
[Attachment 55818 - Click to enlarge]
[Attachment 55819 - Click to enlarge]
I totally agree with you, i won't be able to use QTGMC, i'll go with TFM for sure.
I will recap here :
SOURCE = Dvd 25fps PAL
OUTPUT = deinterlace (your script) + crop + change fps + Lagarith, same colorspace.
Does deinterlace could be even better if i don't care about about processing time ? And is 24 FPS better than 23.976 ?
This script (taken from you, edited) does 24fps without stretcfhing ?!
AudioDub(a,v)
TFM()
Crop(10,2,-6,-2)
QTGMC(InputType=2)
AssumeFPS(24000, sync_audio=false)
ConvertAudioToFloat().TimeStretch(rate=(24000.0/25.0*100.0)).ConvertAudioTo16Bit()
prefetch(8)
When process's finished i have an AVI deinterlaced (and well) i can reencode with any encoder (Handbrake.......).
Tomorrow i'll install AviSynth+ an d see if i can make it work. -
Where can i find the TFM ?
EDIT = waking-up, thanks, i had the Tdeint, but not the ivct
http://avisynth.nl/index.php/TIVTC
If you just want to deinterlace those few frames needing it, an alternative is TDeint(Full=False)
http://avisynth.nl/index.php/TDeint
It can also be made to only use its interlace detection but with a different deinterlacer (one such as QTGMC). -
And i install Avisynth+ anyway ? Not normal 2.6 or the MT by SEt (mutithread .dll on QTGMC page, should i)
It is time to install all the stuff !
EDIT : I retained from QTGMC' page reading :
MVTools2
Nnedi3
Zs_RF_Shared.avsi
TDeint
EDIT : if ever you want the French DVD menu (go right after chapter 6 to access 7-12, no mouse click) :
https://drive.google.com/file/d/1Oht-r3cRfJzF_ECUqx4_uzNQwj-3Mebg/view?usp=sharingLast edited by KlemNT; 12th Nov 2020 at 20:58.
Zs_RF_Shared.avsi is a bunch of simple functions commonly used by other filters. Instead of having all the other functions include a copy, or of having ~80 different AVSI files, they're all in one place.
It's plain text so you can download it and read it with NotePad. -
And it works also with the "+" version !
https://github.com/realfinder/AVS-Stuff
avs/avs+ Stuff
"Zs_RF_Shared.avsi" in "avs 2.5 and up" is needed for most scripts
To-Do-List
To-Do-List
use avs+ FunctionExists instead of try catch when avs+ is used
add frame properties
more updates
EDIT : i can take the fonctions from this file and copy it to my script....... -
I should download plugins by this page, actually i had mpeg2source error in VDub, i loaded DGDecode DLL (script) AVS+ uses the same .dll found in MeGui X64
http://avisynth.nl/index.php/AviSynth%2B_x64_plugins
Fixed.
(TDeint is v1.7 = https://github.com/pinterf/TIVTC/releases)
Actually i haven't added another plugin.dll than DGDecode in AVS+ i can open .m2v by (hey it's my first script, one dll) :
LoadPlugin("C:\Utilities\AviSynth+\plugins64+\DGDecode.dll")
Mpeg2Source("3AM-VDemux.d2v", CPU2="ooooxx", Info=3)
Crop(10,2,-6,-2)
AssumeFPS(24000)
prefetch(8)
v = Mpeg2Source
it's not recognized as a video (error), that's because it requires the fonctions of QTGMC....... i presume. Or TFM !!
EDIT : mmmhh :
To do deringing only:
MPEG2Source("project.d2v", cpu2="ooooxx")
MPEG2DecPlus
http://avisynth.nl/index.php/MPEG2DecPlus
I could try that ?
MPEG2Source("[PATH\]project.d2v")
To do plain YV12 decoding
idct = 4
avx2 (i7 9700)
upConv = 0
No conversion, YUV420 source is YV12 output
iCC = true
force field-based (interlaced) upsampling. Only if you want to force DGDecode to use a particular upsampling mode.
i420 = true
What is upsampling in that case (mpgsource iCC), use for denintrerlacingLast edited by KlemNT; 13th Nov 2020 at 04:25. Reason: m.à.j script (update)
I just edited my previous post, it has my first script attempt
I see time is not displayedthe same in VDub timeline (frames are) if video loaded from .avs.
That's the video infos :
[Attachment 55822 - Click to enlarge]
Resizing after deinterlace PAL DVD w/ QTGMC
By rilopes64 in forum DVD RippingReplies: 11Last Post: 3rd Dec 2019, 10:01 -
newbie to AVISynth & VirtualDub-need help with IVTC & deinterlace via QTGMC
By clashradio in forum Capturing and VCRReplies: 79Last Post: 14th Nov 2018, 20:05 -
Which DVD to use? PAL or NTSC, and which Deinterlace/Detelecine options?
By U2Joshua in forum Video ConversionReplies: 17Last Post: 16th Jan 2017, 19:59 -
Best DVD source for ripping? PAL or NTSC? deinterlace/detelecine options?
By U2Joshua in forum Newbie / General discussionsReplies: 2Last Post: 12th Dec 2016, 20:04 -
Smart render. Lagarith > Vegas(edit) > Lagarith.
By ValentineStone in forum Video ConversionReplies: 11Last Post: 5th Oct 2016, 13:31
