I use Adblock Plus to reduce annoying ads when looking at websites. ( I don't use it on Videohelp). However, on some websites, the website display is blocked, and there is a message that I must turn off the ad blocker to be able to look at the website. Is there anyway around this problem?
Can't say this has been much of an issue for me recently. Use multiple browsers.
ublock origin for firefox is an alternative to adblock plus.
Brave browser (chromium based) also has a built-in adblocker.
I don't adblock on Chrome. -
SOMETIMES disabling Javascript is the workaround.
The "interesting" part is, those [CENSORED] sites /pages say the same thing even when there is NO AdBlock Plus installed...
apparently /probably they make no distinction between AdBlock Plus itself and similar extensions (e.g., an ad blocker for YouTube specifically)
--- not to mention the pop-up blockers "embedded" in browsers such as Waterfox and Opera."Programmers are human-shaped machines that transform alcohol into bugs." -
I've had that problem too, in the end I had to turn of the ad blocker.. but maybe there's a better solution..
I use noscript but that also has issues. Some sites have 20 or more javascripts running and you have to try to figure out which one you have to turn back on to even view the website or to use some of the sites features. Usually it is the main site script but not always.
Extraordinary claims require extraordinary evidence -Carl Sagan -
If i really like the site i turn it off only for that address.
The Opera browser has it's own built-in ad blocker. You can choose to block or allow both ads and trackers. Quite often allowing ads but blocking trackers makes the sites a lot more usable.
"Well, my days of not taking you seriously are certainly coming to a middle." - Captain Malcolm Reynolds
PC Screen turned static than black
By MetalKoromon in forum ComputerReplies: 1Last Post: 15th Jul 2020, 18:18 -
Adblock
By Jomapil in forum ComputerReplies: 2Last Post: 24th Jan 2020, 10:16 -
Panasonic AG 5700 SVHS Deck turned on after some time
By Maja in forum Capturing and VCRReplies: 2Last Post: 9th Jan 2020, 20:00 -
Should de-interlace be turned on ?
By rodsters in forum DVD RippingReplies: 1Last Post: 1st Nov 2018, 14:12 -
How to Rip CC Subtitles from Websites?
By Ripping in forum SubtitleReplies: 4Last Post: 5th Sep 2017, 12:06
