I have a Problem with my Blu-ray Player, cause it used to be connected with my Wifi, but for whatever reason he isn't able to do that anymore..
I tried to restart the WiFi Router, and I turned to Blu-ray Player off and on, but I did't help!
Any tipps?
	Try re-entering the wifi password on the Blu-ray player. (I had a similar issue were a TV decided after a few years it didn't want to connect to the wifi anymore. Re-entered the password & and it's been fine ever since).
	Hi Julia 34,
 Before your Blu-ray player gets stuck with more internal mistakes and ends up being useless, it might help to have insurance for your devices. Often they help to reduce costs when you need to replace it or need some external help from a professional. What I usually do when I get something new that I want to keep for longer, I get informed about all the possible insurances. This article helped me a lot: https://www.fitformoney.de/haftpflichtversicherung/.
 Wish you the best
	Hi!
 On your Blu-Ray player can you search for wifi Networks aroud you?
 I ask you this in order to know if the built-in wifi adapter is still working.
 If yes , then try to re-enter the wifi key for your wifi network.
 Did your router proceeded to a firmwae update recently and then may have blocked your bluray player?
 Best regards
	It has only happened a few times, but I've had other streaming devices lose the WPA-2 password and then it had to be re-enabled from scratch. I'm pretty sure that my Oppo BR players (earlier than the final series of models) had only optional, external Wi-Fi adapters. One of them had a special and irreplaceable firmware with desirable features that were later withdrawn, so I deliberately never connected it to the home network, lest that receive an unwanted update. The other one could be connected to stream Netflix, Amazon, etc., but this winds up being redundant with some other, more up-to-date streaming options. I never came across any convincing evidence that I was missing much by virtue of not having access to the extra BD+ content that some discs announce. Or am I mistaken about the value of that ? BR discs already provide plenty of room for Extras, should the studio care to include any. When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
  After downloading Pavetube ripper my Blu-Ray player won't recognize no diskBy mightymark in forum Blu-ray RippingReplies: 20Last Post: 4th Dec 2018, 19:36
  Computer DVDs won't play on Blu-Ray playerBy ECKJR in forum DVD & Blu-ray PlayersReplies: 8Last Post: 2nd Oct 2018, 17:40
  Why Won't This Play On Settop Blu-ray Player ???By NewTwoVideo in forum Video ConversionReplies: 6Last Post: 22nd Jun 2018, 10:52
  region free blu ray player suddenly won't play certain set of disksBy fredgarv in forum DVD & Blu-ray PlayersReplies: 4Last Post: 19th Apr 2018, 22:56
  Sony BDPS5500 Blu-ray Player VS Samsung BD-J5700 Blu-ray PlayerBy tarzan54 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jan 2016, 20:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
