I usually get very big file sizes, I converted a 9 MB clip to 60fps using Framerateconverte in Hybrid avisynth tools which turned into 560 mb, it was a 360p video with limit of bitrate upto 50000 changed 2pass to 1 pass)
And without converting it to 60 fps it turned to 50mb without changing anything and keeping default settings I only made it 1pass instead of 2 pass (it's still big!)
I mainly use 264 encoding I tested bunch of others sizes were still big
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Basically:
Code:file size = bitrate * running time
That is why constant quality (CRF) encoding was invented. With constant quality encoding you get the quality you specify but you don't know how big the file is going to be. With bitrate based encoding you know how big the file is going to be but you don't know the quality.
What software encodes 4K 60FPS HEVC @ 60FPS?
By Davekyn in forum Video ConversionReplies: 6Last Post: 7th Apr 2020, 11:25 -
How to convert a video from 30fps to 60fps by FFmpeg ?
By kwanami in forum Video ConversionReplies: 8Last Post: 3rd May 2018, 23:58 -
Convert x265 4k to 60fps
By raumi19 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2017, 09:49 -
How can I convert a video to 60fps without changing speed?
By fighuass in forum Video ConversionReplies: 9Last Post: 6th Mar 2016, 06:59 -
How do I convert a video to 60fps without loss?
By fighuass in forum Video ConversionReplies: 3Last Post: 30th Dec 2015, 11:12
