what's the easiest video convert program what can cut out parts of movies
Results 1 to 14 of 14
LosslessCut, its small, free and can edit easily, f.e mp4s, without converting them or transcoding them when exporting.
simple question: not so simple answer.
Just a few questions for you, what is the format of your source and what do you want to cut out? -
In order to answer your questions you need to give relevant info instead of holding you arm up in the air and cry that it does not work
And it depends on if you have windows or apple. I have windows and can recommend the program windows movie maker. It's free. I don't know if you're more a beginner or an expert in this field, but the windows movie maker is more suitable for beginners because of its easy handling. If you want something more professional, the Adobe Premiere Pro CC is recommendable, but it costs. Another alternative for a free but professional video tool is DaVinci Resolve.
Wenn es möglich wäre, der Menschen Gedanken in einem Video zu speichern, gäbe es noch mehr Gruselfilme ;) -
many thanks for your reply will try this too
Originally Posted by videosuechtig20
Re: video editing
And it depends on if you have windows or apple. I have windows and can recommend the program [url=https://www.videohelp.com/software/Windows-Movie-Maker -
video editing
By celtico in forum EditingReplies: 4Last Post: 7th May 2020, 16:26 -
Video editing?
By My1belle in forum Newbie / General discussionsReplies: 8Last Post: 31st Oct 2019, 17:03 -
Video Editing Insert Translation Voice into video
By kamalakar108 in forum Newbie / General discussionsReplies: 3Last Post: 17th Apr 2019, 00:34 -
Laggy video after editing video on premiere and lagarith codec
By banane1 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2019, 11:09 -
video editing
By Corel user in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2015, 16:51
