I have one working and one with power problem. I tried to change HD and my recordings doesn't start. It only get black in the preview menu and the recorder freeze. Has the models different firmware?
i think you have to format the drive first in the working recorder before you'll be able
to record on to it. you might try connecting the HDD to your PC and see if you can get the recordings off
the HDD. -
I can record with a hdd from another recorder in the same model. But i can't watch the previous recordings recorded in the other same model. Does some models have different firmware? I can't understand why the can't be played in the same working model.
Samsung DTB-P770V
By OldSchool297 in forum DVB / IPTVReplies: 2Last Post: 2nd Oct 2023, 00:01 -
Samsung dtb-p770v power problem.
By OldSchool297 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 3rd Sep 2020, 19:38 -
Canīt change region code anymore - Samsung BD-J5100
By shuiten in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th May 2019, 12:11 -
Change App Store Samsung BD-J5700/ZC
By aeman1 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Jan 2018, 18:01 -
Samsung writer won't reinstall, not supported by Samsung
By blacktooth in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Jan 2017, 23:47
