Hey guys,
my dad gave me this DVD-VCR combo after having some audio and video issues trying to convert some of his tapes to see if I can fix it. It's an inexpensive unit from 2003 but I don't think it was used much. Didn't really have any dust inside. I cleaned the VCR heads but the issues still remain.
I tried several tapes and depending on the tape it's either diagonal lines running across the screen while the audio is fine OR irregular audio buzz with no or very slight diagonal lines. The DVD section works fine. What might be the cause? Maybe bad capacitors?
Video issue: https://youtu.be/ic-tzwwn54A
Audio issue: https://youtu.be/9H_WIdiZjOM
(the horizontal flicker is from the phone recording)
Results 1 to 1 of 1
Tape converted perfectly, but tried again and now output has diagonal lines
By pinkfan in forum Capturing and VCRReplies: 3Last Post: 6th Jan 2019, 02:36 -
Audio Buzz
By Skeeter1 in forum AudioReplies: 5Last Post: 17th Nov 2018, 06:44 -
audio buzz when there is no audio playing
By Hypersonic1 in forum Capturing and VCRReplies: 11Last Post: 2nd Dec 2017, 10:45 -
Best method of removing buzz from captured audio
By snafubaby in forum Capturing and VCRReplies: 4Last Post: 31st Jan 2016, 18:46 -
Issue with lines repeating - over and over again....
By Greg2041 in forum SubtitleReplies: 4Last Post: 8th Jan 2016, 17:21
