Hi,
has anyone found a way to create custom presets with their own settings in XMediaRecode?
No doubt it is a great tool but it has so many parameters that can be set, and not having a way to save pesronal settings (I hope there is one, but I can't find it anywhere...) forces you to set all of them from scratch everytime you want to use it. This is really annoying and time consuming.
I've found the function to create presets even in little and crappy apps, I can't believe it's not available in this one.
Thanks in advance.
"Long live R 'n' R"
You have to do it manually in the app folder.
Navigate to the install folder, open here or similar: "C:\Program Files\XMedia Recode 64bit\Profile"
Save one profile set to edit and delete the rest. (You may also choose to keep which profiles you want)
e.g. keep all the files titled HTML5 (the .ini and the .xmrpres files) and delete the rest
Copy and rename to suit you.
e.g. you can rename the file set as Anime, so Anime.ini, Anime_1280x720_mp4.xmrpres etc
Edit the .xmpres files using Notepad
A lot of the presets are legacy anyway, so deleting them removes useless clutter.
Maybe you still have a Zune? You can choose to keep that profile. -
Thanks blud7,
I got rid of all those presets I've never used!
However, I still heven't found a way to save a preset with my own settings. When I use an already existing preset and try to change some parameters, I have much less options than those I have when I select "custom" profile.
For example, if I chose to keep youtube profile, I only have one audio codec available. I tried to edit the corresponding .xmpres file, but I got lost in there.
I would expect to be able to create a preset by choosing from all available options for each parameter.
Anyway, thanks again for your suggestion, I'll try it again."Long live R 'n' R" -
"Long live R 'n' R"
Nah, it won't save theses specific settings only the codec setting which is more important for me
Save capture settings Virtualdub 1.9?
By hpcampr in forum Capturing and VCRReplies: 4Last Post: 7th Feb 2022, 16:40 -
VHS Conversions - Audio Save Settings
By myladydeb in forum Newbie / General discussionsReplies: 6Last Post: 7th Feb 2022, 06:48 -
Save Settings for VHS Conversions for Best Audio Sync and Quality Picture
By myladydeb in forum Newbie / General discussionsReplies: 6Last Post: 3rd Feb 2020, 00:09 -
No experience with XMediaRecode. No help file. Who can help with settings
By cuneiform in forum Video ConversionReplies: 4Last Post: 7th Sep 2019, 16:13 -
How do I rip Blu-Rays, with a custom crop settings?
By 2ears1mouth0brain in forum Blu-ray RippingReplies: 4Last Post: 20th Jun 2016, 01:26
