I'm capturing off of a PAL VHS, and i've written the following script that should trim the overscan area, stretch what's left to 768x576 (I'm playing back the resulting video on a player that will not honour Pixel Aspect Ratio, so square pixels it is), and de-interlace to 50p. Is this script OK, or have I done anything wrong?
I have an Intel 10900 CPU which has 10 cores & 20 threads.
I'm wondering about colour space, I'm capturing from the VHS using YUY2 (this is simply the default my capture card - Magewell Pro HDMI - has chosen), is this right? And do I need to convert it to anything else in the AviSynth script? I've done a test run and it all looks fine to me, however.Code:SetFilterMTMode("QTGMC", 2) FFmpegSource2("CapturedVideo.avi", atrack=1) AssumeTFF() QTGMC(Preset="Very Slow", FPSDivisor=1, Edithreads=5) Crop(8,0,-8,-0) Lanczos4Resize(768,576) Prefetch(18)
That looks ok for 4:3 SD video. You may need to convert to YV12 at the end depending on what your encoder expects. Specify rec.601 (aka smpte170m) when you encode. If you're going to upload to youtube you'll want to convert to rec.709 with ColorMatrix(mode="rec.601->rec.709").
Also, I recommend to test on a sample whether 'Edithreads=5' really is the best choice, it seems rather high and higher isn't always better. Lower value might provide more speed.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
I'm encoding using x264 (8 bit) using YUV422 (in VirtualDub) right now, if that helps.
Best & easiest way to de-interlace in avisynth/MeGUI?
By WAusJackBauer in forum Newbie / General discussionsReplies: 80Last Post: 29th Sep 2022, 08:24 -
Whats wrong with my Avisynth script?
By geordie10 in forum RestorationReplies: 5Last Post: 18th Aug 2019, 18:19 -
Avisynth crop caused weird Aspect Ratio
By pooksahib in forum Video ConversionReplies: 12Last Post: 11th Jun 2019, 15:42 -
Avisynth for interlace problem
By lordsmurf in forum RestorationReplies: 5Last Post: 3rd Jan 2018, 08:08 -
from 4:3 to 16:9, in crop/resize mode and avisynth 64 bit?
By marcorocchini in forum Newbie / General discussionsReplies: 27Last Post: 25th Oct 2017, 21:45
