When capturing my initial AVI file, what colour space should I use? I have a host of options available to me in VirtualDub, the default being YUY2. I have a Magewell Pro HDMI capture card.
After capturing the file, I would like to remove the black bars either side, stretch what's left to 768, and de-interlace with QTGMC, for playback on a computer (using square pixels), if that might influence my selection of colour space at capture-time.
I would suggest you do some research first, there is already a lot of knowledge available through previous questions & answers, Google can be a great help, and may worker faster for you,
also if you first learn some of the basics that has been answered so many times.
Much more simpler software might work better for you, VirtualDub has a steep learning curve, with more basic knowledge you can do more with Virtualdub. -
YUY2(4:2:2) all the way until you get to your playback/distribution format, and then that would be YV12 (4:2:0).
What resolution for capturing AVI from a PAL VHS player? 720 or 768?
By bergqvistjl in forum Capturing and VCRReplies: 57Last Post: 19th Sep 2021, 00:24 -
Colour issues with DVD copy of VHS transfer
By paul92 in forum RestorationReplies: 1Last Post: 26th Aug 2020, 10:56 -
Problems capturing pal-n VHS
By maticava in forum Capturing and VCRReplies: 2Last Post: 13th Jun 2020, 12:54 -
Is a UK PAL video tape compatible with a continental Europe PAL VHS/S-VHS p
By arjaydavis in forum Capturing and VCRReplies: 7Last Post: 21st May 2019, 04:38 -
Newbie advice needed - Capturing PAL VHS
By Gameshow Host in forum Capturing and VCRReplies: 42Last Post: 28th Apr 2016, 11:49
