I'm not quite sure to explain my issue fully, but I have a music video, in 29.97, if I IVTC it, its nearly perfect, however, it has issues on crossfades, where it cant decimate the dupes properly because the dupes are in different places on each layer of the crossfade.
See the de-telecined snippet attached below. Go frame by frame, and you'll see what I'm talking about.
I also included the untouched m2v for you to experiment with.
	I would use manual overrides and/or replacement frames for that section (or if you want better results, combine some areas with masks) .
 Replacement frames can come from deinterlaced versions such as QTMGC, yadifmod2/nnedi3 . Some areas you might not want to use QTGMC because it can blend more.
 You can mix/match frame versions using remapframes in avisynth or a NLE (or parts of frames using masks/roto)
 If you use TFM(pp=0).TDecimate() - that is your "base" decimation. You can see the decimation is correct, but there are combed frames (because pp=0) . So use that as your timing guide (baseclip in remapframes, or base layer in a NLE), and repair the combed areas
 (and some other issues like other minor combing and rainbows you might want to address)
	eg. using TFM(pp=0).TDecimate() as the "base" and QTMGC as the sourceclip for replacement frames
 The way I like to work is avspmod. You identify the frames for remapframes base numbers in one tab, QTGMC numbers in a 2nd tab. For short sequences faster than going into a NLE.Code:MPEG2Source("snippet.d2v") tfm(pp=0) tdecimate() t=last MPEG2Source("snippet.d2v") AssumeTFF() QTGMC(sharpness=0.5) q=last remf(t, mappings=" 4 10 6 15 7 17 8 20 10 25 12 30 14 35 16 40 18 45 19 47 20 50 22 55 23 57 24 59 ", sourceClip=q) trim(2,0)
 Timing wise it's correct and some people might just leave it like that. Personally, I would go a step farther and add back details /blurring lost by QTGMC , or combine different deinterlacers. For example, that hat "shady" text is slightly blurred on some of the replacement frames. You can mask it out and bring back the original version with some minor roto work
  Total failure trying to crossfade using VSDC Video EditorBy OldNick in forum EditingReplies: 4Last Post: 29th Jun 2019, 00:41
  8mm transfer vertically misalignedBy tom_nito in forum EditingReplies: 6Last Post: 24th Nov 2017, 14:27
  Need Video player with video crossfadeBy khan.cross in forum Software PlayingReplies: 1Last Post: 27th Mar 2017, 20:25
  how to Telecine in handbreakBy jamespoo in forum DVD RippingReplies: 9Last Post: 23rd Jun 2016, 11:37
  Interlacing misaligned when capturing from old visit tapeBy animatorgeek in forum Capturing and VCRReplies: 2Last Post: 14th Nov 2015, 11:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
