  1. I want to scale a video and burn the subtitles in it.
    According to FFMPEG documentation:
    https://trac.ffmpeg.org/wiki/HowToBurnSubtitlesIntoVideo
    https://trac.ffmpeg.org/wiki/Scaling
    The correct syntax would be:
    ffmpeg -i video.mkv -c:v libx264 -c:a ac3 -crf 14 -ss 00:03:15 -to 00:03:37 -vf subtitles=video.mkv, scale=720:-1 output.mp4
    But it doesn't work, it seems ffmpeg doesn't recognize scale=720:-1 even if the documentation says it should work.
    Where is the problem in the syntax?
  2. Code:
    remove the whitespace
    also for the future: post the output ffmpeg posts, since it usually does report what's wrong,...
  3. I see, thanks for the help.
