So I had an mkv file, which I converted to mp4 using the command
>ffmpeg -i baby_cakes.mkv -codec copy baby_cakes.mp4
Info obtained from ffprobe for mkv file:
encoder : libebml v1.3.4 + libmatroska v1.4.5
Duration: 01:19:52.54, start: 0.000000, bitrate: 1747 kb/s
Stream #0:0: Video: h264 (High), yuv420p(progressive), 640x480 [SAR 1:1 DAR 4:3], 24 fps, 24 tbr, 1k tbn, 48 tbc (default)
Stream #0:1(eng): Audio: mp3, 24000 Hz, stereo, fltp, 64 kb/s (default)
Info obtained from ffprobe for mp4 file is:
encoder : Lavf58.29.100
Duration: 01:19:52.54, start: 0.000000, bitrate: 1752 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 640x480 [SAR 1:1 DAR 4:3], 1682 kb/s, 24 fps, 24 tbr, 16k tbn, 48 tbc (default)
Stream #0:1(eng): Audio: mp3 (mp4a / 0x6134706D), 24000 Hz, stereo, fltp, 64 kb/s (default)
So I noticed there is a slight increase, (mkv) 1,022,545 KB vs (mp4) 1,025,022 KB
Q1. Why has the video stream increased in bitrate, from 1747 kb/s vs 1752 kb/s ?
Q2. What does the numbers for `tbr` mean ? The change is 1k tbn (mkv) vs 16k tbn (mp4)
The single streams are exactly the same.
The differences are due to different headers and metadata. You can test this by muxing the mp4 back into an mkv. -
tbn = the time base in AVStream that has come from the container
tbc = the time base in AVCodecContext for the codec used for a particular stream
tbr = tbr is guessed from the video stream and is the value users want to see when they look for the video frame rate
see: http://ffmpeg-users.933282.n4.nabble.com/What-does-the-output-of-ffmpeg-mean-tbr-tbn-t...-td941538.htmlusers currently on my ignore list: deadrats, Stears555, marcorocchini
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
Raw DV to a better Container (MKV, MP4) for Archiving
By Sathwik in forum Video ConversionReplies: 1Last Post: 18th Jun 2020, 08:09 -
DVD conversation to MKV container.. what codec?
By MwBakker in forum Newbie / General discussionsReplies: 31Last Post: 29th Feb 2020, 20:02 -
youtube needs mp4 container but my VE does not have it
By Anonymous754 in forum Newbie / General discussionsReplies: 20Last Post: 19th Jan 2019, 15:08 -
Having a Hard Time Understanding MKV
By dualdivx in forum Video ConversionReplies: 3Last Post: 25th Dec 2015, 08:13
