Have not had a chance to tear into it, but, I used my 'ripping' computer a week ago, been off ever since. Turned it on and it powered up for 2 or 3 seconds and shut off. Over and over. Actually, I have it & monitor & stereo speaker on a power strip. I turn off the power strip after powering down the computer normaly. Turn on power strip and above happens, one time. After first attempt, noyhing happens at all. I have to power off & then back on to repeat. I dont know, maybe the power supply? Like I said, have not had a chance to do anything, , , yet.
-corne-
Also, I have not modified anything on the computer for months.
Results 1 to 9 of 9
Yes, no, maybe, I don't know, Can you repeat the question?
Sounds like a failing power supply to me...
...or onboard power delivery system on the motherboard (bulging or leaking capacitors are one sign). -
About 10 minutes ago before anything else, I jiggled all the connections on the back of the computer in question. Lo and behold! It started right up! My kinda luck.
-c-Yes, no, maybe, I don't know, Can you repeat the question? -
"Jiggling" is not the best idea. Better to fully unplug & fully reseat, confirming solidity of connection.
Scott -
That also means to check your video card and ram and other devices internally since any kind of movement can get them going on/off.
Stuck Power on button? Starting and then Hard powering off from power button depressed and held?
I had this with a friend's father's PC a couple of weeks ago. I'm guessing a bit of oxidation on some of the connectors . . . ?
"Well, my days of not taking you seriously are certainly coming to a middle." - Captain Malcolm Reynolds
Whats with the colors/chroma in this source?
By killerteengohan in forum RestorationReplies: 3Last Post: 22nd Jan 2018, 08:03 -
Whats with these artifacts and I can I reduce or remove them?
By killerteengohan in forum RestorationReplies: 3Last Post: 18th Oct 2017, 23:11 -
Whats the Best DVD Authoring Software
By jcool26 in forum Authoring (DVD)Replies: 29Last Post: 28th Jun 2016, 14:15 -
Whats with the glowing lines/edges??
By killerteengohan in forum RestorationReplies: 6Last Post: 3rd Jan 2016, 10:24 -
Whats best video converter
By loa909 in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2015, 20:59
