Hello
I bought a Panasonic UB9000 a couple of months ago. I made it region-free (on dvd) using a remote i got on Ebay. (Btw I'm from Europe), and the player works very well.
Yesterday i bought Titanic (Blu-ray, 3d and dvd - 6disc edition). And it won't play the dvd. Not a big problem since i bought it for the blu-ray, but still...Why won't it play the dvd?
Any ideas why...? Thanks...
did you try cleaning the dvd disc ??
what region is the Titanic box set from ? -
It's region 2.
This one:
https://www.blu-ray.com/movies/Titanic-3D-Blu-ray/54618/
I've tried the dvd on both a Marantz and an Oppo, and the disc plays without problems. The message i get: "This disc is not formatted to play in this region." Strangest thing... -
Was the Panasonic UB9000 originally Region A for Blu-ray and Region 1 for DVD? Maybe the DVD's video format is the cause of your problem. Region 1 uses NTSC format for DVD and Region 2 uses PAL format for DVD. I have an old Panasonic DVD player/recorder that is Region 1/NTSC which rejects PAL format DVDs even if the DVD itself is all-region.
It appears that davexnet reached the same conclusion while I was typing.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
And the simplest way to test this is to play another PAL disk in this player.
But I see that Amazon UK sells this player as a modded Region Free. Anyone in the UK would expect it to play their standard PAL disks unless the mod also took care of that.
But one other thought as well. Have you recently performed any firmware update. -
It's a region B and region 2 player. And the Titanic disc is a region 2 dvd...and it's only the Panasonic that won't play it.
Region free dvd player
By thyer2a@bigpond.com in forum Newbie / General discussionsReplies: 1Last Post: 30th Dec 2019, 04:24 -
Region free Samsung D530 R4 player skips play on some NTSC DVD's!
By stew181 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 3rd Mar 2019, 11:19 -
Question About Buying A Region Free DVD Player
By jlurban6731 in forum DVD & Blu-ray PlayersReplies: 20Last Post: 14th Jan 2019, 23:11 -
region free blu ray player suddenly won't play certain set of disks
By fredgarv in forum DVD & Blu-ray PlayersReplies: 4Last Post: 19th Apr 2018, 21:56 -
region free dvd-player
By CocoChanel in forum DVD & Blu-ray PlayersReplies: 5Last Post: 30th Jan 2018, 02:48
