Good evening to everyone, I need a take. A relative of mine has to do a bunch of S-VHS (PAL) tapes captures, to then, both burn to a dvd with Encore and produce avc/hevc files to store on a hdd. He was given a Blackmagic Intensity Shuttle for the job.
On the control panel, though, the only output options appearing for standard def were either 625i50 or 625p50, but no 625p25 (of course deinterlaced by the card). I thought 50p capture from a 50i source wouldn't be optimal, so I choose 50i output. At this point I'm asking you, more experts, what to do, if to work with interlaced footage, choose 50p, or perhaps upscale the output to 720p25. I would like to avoid deinterlacing footage in post by the way, as well as dealing with combing artifacts.
Thanks in advance![]()
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
You can't use 720p on a DVD. You should keep it interlaced (50i) for the DVD, the exact process depends on what software you're planning to use for it.
The point is may getting interlaved footage give me issues? Will the dvd be combing artifact-free? And especially the h.264/h.265 files. This because I've seen interlaced footage either play smoothlly on pc or have terrible artifacts, even after setting the correct field order.
I'll be sending Premiere Pro CS6' timeline to Encore. Then the encoding of mp4 files will happen in Media Encoder CC2020. -
DVD is natively interlaced. You will have no problems with it unless you screw something up. And you cannot put h.264 or h.264 video on a movie DVD, only MPEG 2. The MP4 contains is not supported either.
The best procedure is to capture 25i (50i is just the new name for 25i) with a lossless codec then edit/filter/encode to MPEG 2 for DVD. Author with your choice of DVD authoring program. -
I thought DVD could be progressive too. By the way mp4 files have nothing to do with dvd, they would be stored on a hdd. About those, if I choose the correct order, I won't get any artifacts, right?
By the way I'm recording tapes in huffyuv + pcmLast edited by Tek03; 6th Nov 2020 at 12:28. Reason: typing mistake
DVD has its roots in the days of interlaced analog TV. It fully supports interlaced video.
If you encoder interlaced with the correct field order you will not see comb artifacts when you watch the DVDs on a TV. Some players may not be set up correctly to play interlaced h.264 correctly. If you're sending video to others it would be best to convert those to progressive.
Perfect. -
All right then, I'll work with 50i for the DVDs and then for the MP4s, I'll just export them in progressive and media encoder will hopefully deinterlace them properly.
Thank you all for the answers. -
@Tek03, DVD CAN be progressive, but it should only be set that way if the original source was that way. In your instance, you have a (S)VHS source, which is ALWAYS interlaced (although it could be from a telecined film, and using IVTC would be the only proper way to make that progressive again). Jagabo has you on the right path.
avisynth 50p to 50i: how to avoid the flickering artifacts?
By marcorocchini in forum Newbie / General discussionsReplies: 15Last Post: 20th Jul 2019, 10:58 -
Repair Jumping Frames and make a 50p from 50i with QTGMC
By diginoob in forum RestorationReplies: 44Last Post: 13th Aug 2018, 22:53 -
Your Best method to make 50i to a 50p file
By diginoob in forum RestorationReplies: 18Last Post: 29th Aug 2016, 06:38 -
50i or 50p?
By Mabel in forum Newbie / General discussionsReplies: 23Last Post: 3rd Mar 2016, 03:06 -
Converting AVCHD 50i to mp4 50P.
By infinifc in forum Video ConversionReplies: 23Last Post: 13th Dec 2015, 08:01
