Im not sure about video bitrate the default seems to be 910
What would i need to set this to if i want very good quality like almost dvd quality?
Info you might need
Im capturing Video using a Wintv card from a video player
The software im using is Virtual Dub
Im capturing as a divx file
What resolution are you attempting to capture? 120x80? 640x480?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I think its 320 x 288
Virtual Dub doesnt give me a customize tab for some weird reason, and the next highest resolution is 768 x 576 but when i select this i get dropped frames
The pc im using to edit the video is
P3 800
512 PC133 ram
30gig HD lots of space 66udma
kyro 2 64mb
wintv go -
i experiemented with divx 5 for compression when capturing didnt change any settings used pass 1 and bitrate 1150 not sure about a good bitrate yet, and seemed to be alittle smaller file size than the divx4 compression gave me, and the same quality as far as i could tell
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 08:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 21:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Newbie needs bitrate calculation advice to convert my 1st PAL to NTSC
By queen_anne in forum Video ConversionReplies: 35Last Post: 20th May 2007, 22:48
