Trying to take a series of video files and make it into a DVD player playable DVD. I've used Nero a looong time ago and tried CyberLink PowerDirector recently. I'm open to using these again but wanted to know what the best is out there.
Needs
Allow for soft-coded subtitles (can turn them on/off)
Episode selection
Ability to write to ISO and direct to disk
Support dual layer DVDs (bonus if supports Blu-Ray)
"Easter egg" or custom buttons.
flarimeki38Guest
If you need something that can also edit and convert video and audio to be DVD compliant, try TMPGEnc Authoring Works 6. It includes the ability to author Blu-ray and can create custom menus and custom buttons.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
VEGAS DVD Architect is no longer available for sale from MAGIX.
Note that MAGIX's acquisition of SCS products from Sony in mid-2016 included DVD Architects and the next version after that was VEGAS DVD Architect (a.k.a. DVD Architect 7).
Sony/SCS does not sell their former DVD Architect Pro or Studio either. -
Even so, it is still possible to find Vegas DVD Architect and Architect Studio being sold by third parties as boxed software or downloads.
Depends how far down the rabbit hole you want to go. Now and days I use avisynth + hcenc for the video and ffmpeg for the audio. I then use gui for dvdauthor to make my final product. Takes a bit but I like the overall control I have with said solution. For all in ones I used to use tmpeg software. For free avs2dvd is good as well.
if all else fails read the manual
Creating an DVD-authoring software
By dvdmaster1 in forum ProgrammingReplies: 5Last Post: 30th Mar 2022, 17:56 -
DVD Authoring Software advice
By 3-Phase in forum Authoring (DVD)Replies: 8Last Post: 20th Nov 2019, 18:41 -
Surround Sound (Dolby 5.1 or higher) in DVD Authoring Software
By Badwolf in forum Authoring (DVD)Replies: 12Last Post: 24th Feb 2019, 14:24 -
Need recommendations for DVD authoring software.
By AlliS in forum MacReplies: 3Last Post: 2nd Jan 2019, 22:09 -
Whats the Best DVD Authoring Software
By jcool26 in forum Authoring (DVD)Replies: 29Last Post: 28th Jun 2016, 13:15
