I am looking for what I consider to be a relatively cheap (<$50) Blu-Ray authoring program for PC. I have only used Mac based software in the past to create DVDs and I now want to move on to PC based software for Blu- Ray authoring.
I need something that will work with just about all file types and have a library of menus on hand. Prefer a simple to use program.
Results 1 to 10 of 10
AnonymousGuest
None like that really exist. Your best bet is to use DVD Fab Blu-ray Creator, which can be used to do decent stuff with some fiddling.
DVD Architect Studio can author Blu-ray with menus and costs $40 but I'm not sure that it converts video and audio to be Blu-ray compliant. You can try it before buying.
I think Cyberlink PowerProducer Ultra (but not PowerProducer Deluxe) can do everything that you want, although it costs more than $50. You can try it before buying. See www.cyberlink.com/products/powerproducer/features_en_US.htmlIgnore list: hello_hello, tried, TechLord, Snoopy329 -
It does. I have full featured DVD Architect and it re-encodes video and audio. That's why I don't use it and use MultiAVCHD instead.
[QUOTE=Troc;2600724]
No.
I am not sure I follow your question.
RE menu: you can create menus in DVDA.
RE DVDA itself: it is not free. It usually comes with purchase of Sony, now MAGIX, Vegas Pro video editor (which I have). -
Basically, are you tied to a template or can you design a nice menu ground up with custom background, music, your own buttons, text and everything? Can you make a custom submenu, for example for Special Features, or is there a locked number of menu screens that you cannot change?
Depending on the price, if I didn't want to do 4K, I'd be all over that. I might be anyway, since my sly editing of DVDFab Blu-ray Creator is quite limited.
I have previously tried https://tmpgenc.pegasys-inc.com/en/product/taw6.html and it may work for your purpose.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Need a new Blu-Ray Authoring package
By dswalen in forum Authoring (Blu-ray)Replies: 16Last Post: 20th Mar 2020, 08:57 -
3D Blu-Ray Re-Authoring
By paultara in forum Authoring (Blu-ray)Replies: 1Last Post: 7th Apr 2018, 00:33 -
Help - Blu Ray Authoring with multiavchd issue
By sapruitt in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Mar 2018, 11:05 -
Best authoring software for new Blu Ray user?
By stantheman1976 in forum Authoring (Blu-ray)Replies: 28Last Post: 12th Jul 2016, 16:17 -
Authoring blu ray from .ts file
By twinaleblood in forum Authoring (Blu-ray)Replies: 11Last Post: 21st May 2016, 16:27
