What tools does SVP (smooth video project) use?
I heard that SVP uses some open source programs to do what it does, what are those programs (specially the motion smoother one?!
Results 1 to 10 of 10
see: https://www.svp-team.com/wiki/Plugins:_MVTools2SVP 3.0-series contains modified version of MVTools2 Avisynth plugin and we're grateful to all of MVTools authors: Manao, Fizick, Tsp, TSchniede and SEt for developing such a great library.
The Avisynth FrameRateConverter script is an attempt to do the same without the gpu support,..
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
FrameConverter does not use the svpflow*.dlls it does use mvtools2 (latest version does include the modifications svp team did back then), but that's probably the only dependency it shares with SVP.
Haven't compared FrameConverter and SVP for ages, so it might have changed, but last I compared them FrameConverter sometimes was better and sometimes it was worth, depending on the settings. But was always slower than SVP with GPU support.
btw. if you look at Interpolation methods in Avisynth you might also want to look at the other alternatives listed over at http://avisynth.nl/index.php/External_filters#Frame_Rate_Conversion
At least SalFPS3 might be worth a look.
I tested it along with framerateconverter and MvToolsFPSmod and interframe (using a tool called hybrid)
I found this results framerateconverter > MvToolsFPSmod > interframe > SalFPS3 (my opinion only, I wanted more motion flow than less artifacts I also found framerateconverte to be pretty close to DAIN app (which my CPU and GPU isn't capable of!)) -
Happy you like it and it's of some use.
SVP [Smooth Video Playback] and Vapoursynth problem
By celsoac in forum MacReplies: 4Last Post: 15th Mar 2020, 02:39 -
What tools do I need for an uncut project?
By Adam Cole in forum EditingReplies: 2Last Post: 26th Mar 2019, 11:50 -
How do I make a video this smooth? SVP question.
By bradwiggo in forum Video ConversionReplies: 19Last Post: 2nd Jul 2018, 17:25 -
svp
By JekylHyde in forum Software PlayingReplies: 0Last Post: 9th Aug 2016, 17:12 -
Kinetic Typography Video - SVP
By mo7amed3rf4n in forum EditingReplies: 0Last Post: 23rd Jun 2016, 21:12
