Hi all, I've been having a challenge getting my video/audio is sync - any help is super appreciated.
On my previous Android phone, it would record videos out of sync with the audio so I would put it into the program Handbrake and convert from variable bitrate to constant bitrate and it would be perfectly in-sync. Great!
I now have a new Android phone and this isn't quite working. I'm not sure if it's my settings? I run it through Handbrake and the final result is still out of sync, it seems like certain parts of the video are almost slowed or sped up at certain points with the words not matching the lips of the person speaking.
I'm not sure what steps to take. Taking one of the videos as an example, if I run it in the program MediaInfo to see the details it says:
Bit rate: 17.3 Mb/s
Frame rate: Variable
Frame rate: 19 FPS
Min Frame rate: 0.744 FPS
Max frame rate: 30.060 FPS
And other details I coud list.. So in Handbrake, I've tried putting it to constant frame rate of 20 (the closest to 19 there) with bitrate 17300. This wasn't great so great with frame rate 30. Encoder Preset is the default as I'm not sure what this does.
Any suggestions on how I can get these videos in sync with the audio properly?
Sure, here's some footage. This is footage which has run through Handbrake. https://youtu.be/EEXbXuyWyUA
Some footage seems fine then other parts go out like this.
These shots are frame rates 23, 25 and I believe 23 again. This is audio from the converted video.
Thanks! -
Handbrake encoding at Variable FPS when Constant is chosen
By ManiKz in forum Newbie / General discussionsReplies: 7Last Post: 10th Dec 2019, 16:16 -
【HandBrake】Constant quality and RF settings
By 775405984 in forum Video ConversionReplies: 2Last Post: 25th Dec 2018, 23:55 -
Variable Framerate to Constant Frame Rate
By jjcinema1 in forum Video ConversionReplies: 5Last Post: 6th Nov 2016, 21:29 -
Is Handbrake converting my audio or not?
By Foebane72 in forum Video ConversionReplies: 8Last Post: 15th Oct 2016, 01:48 -
HandBrake giving me variable frame rate when I asked for constant
By Bruce Wayne in forum Video ConversionReplies: 4Last Post: 18th Apr 2016, 15:07
