According to my tests Powerdirector produces better video quality in H264 AVC than Vegas with Mainconcept AVC in two passes !!!
Powerdirector only encodes in one pass
how is this possible?
Results 1 to 11 of 11
Which version of Vegas are you using?
I've used every version from 4 through 13 and have logged thousands of hours on Vegas over the past twenty years. I have not, however, upgraded since Magix bought it.
First of all, I hope you do understand that Vegas provides TWO different h.264 encoders: MainConcept and also the Sony/Magix encoder. The Sony/Magix encoder is only single pass, but for HD and high bitrates, it provides much better results than the MainConcept. The MC encoder was really only meant for 640x480 low bitrate encodes (which is why it included a two-pass option).
All that said, I too have never been that impressed with the Vegas h.264 encoder. Given the price of Vegas Pro, I expected better. When I want the best quality, I frame serve from Vegas into MeGUI. -
Im using Vegas 16 and Powerdirector 16
Sony AVC encoder included in Vegas produces much better video quality than MC
If I edit with Vegas and want to export to mpeg4 AVC I also frameserve but I encode with Avidemux -
With very few exceptions, my workflow is to only render master quality formats out of an editor, and then use a dedicated encoder to perform the encodes. Takes a bit longer, but then the editor has less to deal with with its final render, and the encoder ONLY has to worry about encoding (and is better optimized to do so).
This makes the above comparison more of a moot point, because the quality is almost always much better.
Scott -
Depending on the workflow, it could be lossless (of many flavors - lags, huff, ut, magic, etc) or virtually lossless/slightly lossy (prores, cineform, dnxhd, hqx, etc), or some other specialty one (uncompressed, alphachannel-capable, hdr-capable, picture sequence, etc).
Even smart-rendered sequences could still fall under this (dv, mpeg2, h264) if the timeline effected minimal changes to the clips so that it could render w/o re-encoding. I would still call this "master" quality, as that is still the best that could be expected under the circumstances.
VEGAS Pro 17 not rendering AVC/MVC codec
By Risto15 in forum Newbie / General discussionsReplies: 4Last Post: 22nd May 2020, 22:20 -
H265/HEVC to H264/AVC
By Daringbaaz in forum Newbie / General discussionsReplies: 5Last Post: 22nd Sep 2019, 12:34 -
PAFF H264/AVC encoding
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 29th Jul 2016, 16:42 -
can Avisynth encode H264/avc codec?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2016, 15:42 -
CRF of VP8 vs. AVC/h264
By smitbret in forum Video ConversionReplies: 1Last Post: 18th Jan 2016, 18:03
