Is it possible to work with Rec. 601 footage in Resolve? Its color management options don't list it.
Thread: Rec.601 and DaVinci Resolve
It works ok in the studio version; but it might also depend on what specific type of input/output format you use
You can test it yourself with some SD color bars in/out
A workaround if you can't get it to work is to control the RGB conversion and import/export an RGB fromat -
There's a few posts in this thread that say it uses rec.601 or rec.709 based on resolution, but I've not used Resolve myself. Forcing a particular conversion doesn't seem like an option.
https://forum.blackmagicdesign.com/viewtopic.php?f=21&t=59888Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
But then what do I set my color management settings to?
Convert rec.601 into rec.709?
By killerteengohan in forum RestorationReplies: 8Last Post: 15th Jun 2021, 18:25 -
Converting rec.709 to rec.601?
By killerteengohan in forum RestorationReplies: 22Last Post: 13th Jun 2020, 16:19 -
DaVinci Resolve, Youtube and HD?
By Guernsey in forum Newbie / General discussionsReplies: 3Last Post: 3rd May 2020, 15:02 -
how to remove the exactly string colorMatrix(mode="Rec.601->Rec.709") ?
By marcorocchini in forum Newbie / General discussionsReplies: 16Last Post: 10th Aug 2019, 23:40 -
can x264vfw do change rec.601 --> rec.709?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2017, 15:06
