So I've gone on the adventure of digitizing all of my DVDs in the timely year of 2020. I don't have any Blu-rays containing episodic content, only movies, so this solely concerns DVDs with multiple episodes on them.
1. Some of my DVDs have been kind enough to automatically rip themselves into individual episodes, for example my Daria DVD set. Others, like my Rock The Dragon DBZ DVD set, have collected themselves into one singular file. Is there a reason for this?
2. Is there no way to automatically split singular DVD rips by chapter? I know that I can split them manually by inserting timestamps into MKVtoolnix, but that seems like an awfully tedious solution for the current year, and I have a lot of DVDs to sort through.
3. EDIT: Nevermind on this one
You're mixing together what are usually two separate types of disc>file "ripping" methods.
When using MakeMKV to rip from disc into MKV format, you're actually "converting" from the disc structure to MKV file structure. MakeMKV does not alter the quality in any way but it does strip away the disc-specific formatting, which usually includes menu navigation and may include separation of episodes in a TV series depending how the original disc itself is authored. Most TV discs have the individual episodes loaded as separate pieces: Make MKV will recognize this and create individual MKV files for each. But some discs employ a more peculiar format of having all the episodes as one big chunk, like a VHS tape, relying on the disc menu navigation structure to select an episode. MakeMKV usually cannot parse this properly because it ignores menu data: all it sees is the one huge video file, so it dutifully creates one big MKV containing all the episodes. Generally you would need to use another utility to divide this into individual eps.
The other type of "ripping" used to be far more common than the MakeMKV method: you copy the entire disc structure, including all formatting, to your hard drive. This results in one big file, either as a folder or whole-disc image. These are played by software like VLC as if they were actual physical discs, retaining all the menu navigation and options that are normally lost when you "rip to MKV".
This has been my experience with DVDs anyway: I have not used MakeMKV with any BluRays, so your claim of it carrying the BD menu structure over into the MKV file is quite surprising to me. When ripping a DVD, you typically must choose between the versatility of plain MKV files or the full feature set of a complete disc rip: its one or the other. Menu navigation and option management is a separate framework from the actual video content on a disc: conversion to MP4 or MKV strips away everything but the bare-bones video/audio/subtitles. -
for the automatically split singular DVD rips by chapter, see the last post in this post - https://www.makemkv.com/forum/viewtopic.php?f=1&t=690&start=15
Just for clarification, I've been using MakeMKV to both rip directly from discs as well as convert DVD structure rips that were already made with DVD Decrypter.
I retract that statement about the Blu-ray rips giving a navigation menu, I must've gotten my wires crossed on that during the conversion process (I was doing this at like 2:00 a.m. lol), so nevermind.
Regarding splitting the combined episodes, am I pretty much doomed to do it manually?
Thanks, I'll have a look.
Unable to Rip with MakeMKV: Alternative Options?
By koberulz in forum Newbie / General discussionsReplies: 22Last Post: 16th Dec 2021, 07:44 -
FPS Issue on MakeMKV DVD rip, help?
By Vitality in forum DVD RippingReplies: 13Last Post: 24th Oct 2018, 01:55 -
MakeMKV - Some Questions About the Program
By devilcoelhodog in forum DVD RippingReplies: 7Last Post: 2nd Oct 2018, 00:51 -
MakeMKV will not rip any Verbatim DVD+R DL discs?
By Denvers Dawgs in forum DVD RippingReplies: 3Last Post: 28th Jun 2016, 19:55 -
When I Rip My DVDs Using MakeMKV, The Film Title Just Says 'Title_01.mkv'
By ngc1967 in forum DVD RippingReplies: 2Last Post: 25th Feb 2016, 02:40
