I am using vspipe with x265 binary, I have question about frames
for vapoursynth -s, --start N Set output frame range (first frame)
the first frame I type for example 1500 is inclusive(it start for the frame 1500) correct?
for x265 binary when set --frames 5000 is exlusive (Frame 5000 will not be included) correct ?
from programming perspective that how I understand it, but I didnt find anything that confirm what I think
1 frame is barly noticable but I just be sure
Yes
Yes, because frame numbering starts at zero . 0 to 4999 is 5000 framesfor x265 binary when set --frames 5000 is exlusive (Frame 5000 will not be included) correct ?
FFMPEG Audio Cutting
By Silco in forum Newbie / General discussionsReplies: 0Last Post: 12th Oct 2020, 13:18 -
Audio stutter with merging after cutting and re-encoding
By Sotee in forum EditingReplies: 32Last Post: 19th Feb 2020, 18:46 -
Video Edit - Cutting a section of video from a larger video file
By bpatters69 in forum EditingReplies: 14Last Post: 10th Nov 2017, 11:33 -
Audio to video cutting and configuring software?
By ReiKaz in forum EditingReplies: 0Last Post: 26th Sep 2016, 03:54 -
problem with ffmpeg - cutting video and merging audio tracks
By yakov in forum EditingReplies: 0Last Post: 23rd Mar 2016, 13:00
