Results 1 to 15 of 15
  1. Hey,
    I need to edit the properties of an x265 MP4 file.
    Built-in explorer does not show the advanced tags, I just see them using MediaInfo (installed by K-Lite)
    So is there any free tool to edit those extra tags embedded into the MP4 video?
    **Note: abcAvi does not work for x265 MP4/M4V
    ** MetadataTouch also does not open the ones I need.
    ** To be clear, I used HandBrake to encode a video and "Encoding settings:" fields has a huge list of switches, I need to remove that large field!
    Thanks.
  2. To be clear, I used HandBrake to encode a video and "Encoding settings:" fields has a huge list of switches, I need to remove that large field!
    These are not mp4 tags but SEI informations in the video stream.
    ffmpegs bitstream filters allow to remove the SEI info from H.264 and H.265 streams. Details about it can be found through the forum search or google.
  3. Thanks mate, do you have the command line to remove em all?
  4. For H.264:
    "path to ffmpeg" -i "path to input" -c copy -bsf:v 'filter_units=remove_types=6' "path to stripped output"
    one could remove the SEI data (which holds the 'Encoding settings'.
    Note that the x264 authors want those information to be in the streams that are created with their encoder.
    For H.265:
    x265 authors allow to disable the creation of this information using '--no-info'
    using
    "path to ffmpeg" -i "path to input" -c copy -bsf:v 'filter_units=remove_types=39-40' "path to stripped output"
    should remove the sei messages, see nal unit types in http://iphome.hhi.de/wiegand/assets/pdfs/2012_12_IEEE-HEVC-Overview.pdf
  5. Hey
    Thanks for your kind help, since it's x265 I used:
    ffmpeg.exe -i "D:\bin\source.mp4" -c copy -bsf:v 'filter_units=remove_types=39-40' "D:\bin\target.mp4"
    But I get:
    Error parsing bitstream filter sequence ''filter_units=remove_types=39-40'': Bitstream filter not found
    Full Error:
    ffmpeg version 2020-10-28-git-e5be4c5a88-full_build-www.gyan.dev Copyright (c) 2000-2020 the FFmpeg developers
    built with gcc 10.2.0 (Rev3, Built by MSYS2 project)
    configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libglslang --enable-vulkan --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
    libavutil 56. 60.100 / 56. 60.100
    libavcodec 58.112.100 / 58.112.100
    libavformat 58. 63.100 / 58. 63.100
    libavdevice 58. 11.102 / 58. 11.102
    libavfilter 7. 88.100 / 7. 88.100
    libswscale 5. 8.100 / 5. 8.100
    libswresample 3. 8.100 / 3. 8.100
    libpostproc 55. 8.100 / 55. 8.100
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\bin\Documentary.mp4':
    Metadata:
    major_brand : mp42
    minor_version : 512
    compatible_brands: isomiso2mp41
    creation_time : 2020-10-28T12:27:35.000000Z
    Duration: 01:47:09.59, start: 0.000000, bitrate: 500 kb/s
    Stream #0:0(und): Video: hevc (Main) (hvc1 / 0x31637668), yuv420p(tv, smpte170m/bt470bg/bt470bg), 720x576 [SAR 16:15 DAR 4:3], 336 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc (default)
    Metadata:
    handler_name : VideoHandler
    Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 158 kb/s (default)
    Metadata:
    handler_name : Stereo
  6. since it's x265 I used
    remember to simply tell x265 to not create the info in the first place if you don't need/want it.
    since you are on windows using quotes:
    -bsf:v "filter_units=remove_types=39-40"
    should help, assuming your ffmpeg build supports filter_units ("ffmpeg -bsfs" list the available bitstreamf ilters) which it should.
    Cu Selur
  7. Hey thx indeed, and sorry if I'm noob at this
    It worked, but the new file still have the huge "Encoding settings" following by tons of switches/parameters!
    Any advise please?
  8. That is strange since it does work fine here.
    before:
    mediainfo.exe "f:\TestClips&Co\files\5000frames.mp4"
    General
    Complete name                            : f:\TestClips&Co\files\5000frames.mp4
    Format                                   : hvc1
    Codec ID                                 : hvc1 (iso4/hvc1)
    File size                                : 820 KiB
    Duration                                 : 3 min 20 s
    Overall bit rate                         : 33.6 kb/s
    Encoded date                             : UTC 2018-01-27 15:58:44
    Tagged date                              : UTC 2018-01-27 15:58:44
    Writing application                      : Hybrid 2018.01.26.1
    Video
    Format                                   : HEVC
    Format/Info                              : High Efficiency Video Coding
    Format profile                           : Main 10@L4.1@Main
    Codec ID                                 : hvc1
    Codec ID/Info                            : High Efficiency Video Coding
    Bit rate                                 : 31.3 kb/s
    Maximum bit rate                         : 52.7 kb/s
    Width                                    : 640 pixels
    Height                                   : 480 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 25.000 FPS
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.004
    Stream size                              : 764 KiB (93%)
    Title                                    : 265#video:fps=25@GPAC0.7.2-DEV-rev357-g7115eeb89-ab-suite
    Writing library                          : x265 2.6+22-ff02513b92c0:[Windows][GCC 7.2.0][64 bit] 10bit
    Encoding settings                        : cpuid=1173503 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=640x480 / interlace=0 / total-frames=0 / level-idc=41 / high-tier=0 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=25 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=0 / scenecut=40 / radl=0 / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-1:-1 / sao / no-sao-non-deblock / rd=3 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.50 / psy-rdoq=10.00 / no-rd-refine / no-lossless / cbqpoffs=-2 / crqpoffs=-2 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=20000 / vbv-bufsize=20000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=0.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=8 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=5 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / analysis-save=(null) / analysis-load=(null) / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / limit-sao / ctu-info=0 / no-lowpass-dct / refine-mv-type=0 / copy-pic=1
    Color range                              : Limited
    Matrix coefficients                      : BT.470 System B/G
    Codec configuration box                  : hvcC
    processing with ffmpeg:
    ffmpeg -y -i "f:\TestClips&Co\files\5000frames.mp4" -bsf:v "filter_units=remove_types=39-40" -c copy e:\stripped.mp4
    ffmpeg version N-99560-g25e5fc91d1-g6bdfea8d4b+3 Copyright (c) 2000-2020 the FFmpeg developers
      configuration:  --cc='ccache gcc' --cxx='ccache g++' --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libaom --enable-libopenmpt --enable-version3 --enable-libsvthevc --enable-libsvtav1 --enable-libkvazaar --enable-libzmq --enable-libvmaf --enable-vapoursynth --disable-libdavs2 --enable-librav1e --enable-mbedtls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DZMQ_STATIC --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads --extra-cflags=-DKVZ_STATIC_LIB
      libavcodec     58.111.100 / 58.111.100
      libavformat    58. 62.100 / 58. 62.100
      libavfilter     7. 87.100 /  7. 87.100
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'f:\TestClips&Co\files\5000frames.mp4':
      Metadata:
        major_brand     : hvc1
        minor_version   : 0
        compatible_brands: iso4hvc1
        creation_time   : 2018-01-27T15:58:44.000000Z
        encoder         : Hybrid 2018.01.26.1
      Duration: 00:03:20.00, start: 0.000000, bitrate: 33 kb/s
        Stream #0:0(und): Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt470bg/unknown/unknown), 640x480 [SAR 1:1 DAR 4:3], 31 kb/s, 25 fps, 25 tbr, 25k tbn, 25 tbc (default)
        Metadata:
          handler_name    : 265#video:fps=25@GPAC0.7.2-DEV-rev357-g7115eeb89-ab-suite
    Output #0, mp4, to 'e:\stripped.mp4':
      Metadata:
        major_brand     : hvc1
        minor_version   : 0
        encoder         : Lavf58.62.100
        Stream #0:0(und): Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt470bg/unknown/unknown), 640x480 [SAR 1:1 DAR 4:3], q=2-31, 31 kb/s, 25 fps, 25 tbr, 25k tbn, 25k tbc (default)
        Metadata:
    Stream mapping:
      Stream #0:0 -> #0:0 (copy)
    Press [q] to stop, [?] for help
    frame= 5000 fps=0.0 q=-1.0 Lsize=     816kB time=00:03:19.88 bitrate=  33.4kbits/s speed=1.17e+04x
    video:762kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 7.025929%
    after:
    I:\Hybrid\64bit>mediainfo.exe e:\stripped.mp4
    General
    Complete name                            : e:\stripped.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/iso2/mp41)
    File size                                : 816 KiB
    Overall bit rate                         : 33.4 kb/s
    Writing application                      : Lavf58.62.100
    Video
    Format                                   : HEVC
    Codec ID                                 : hvc1
    Width                                    : 640 pixels
    Height                                   : 480 pixels
    Bit depth                                : 10 bits
    Stream size                              : 762 KiB (93%)
    Are you sure you looked at the output and not the input when checking whether it worked?
    (these 'Encoding settings' are SEI messages so the ffmpeg filter call should work without a problem)
    Cu Selur
  9. Hey, thanks so much for the tip, unfortunately yeah I'm sure and both input/output still have that:
    https://forum.videohelp.com/attachment.php?attachmentid=55664&stc=1&d=1603973088
  10. Really strange,..
    to make sure, that MediaInfo Tool you use doesn't cache the results by name, also try if the same happens if you use:
    ffmpeg.exe -i "D:\bin\source.mp4" -c copy -bsf:v "filter_units=remove_types=39-40" "D:\bin\stripped.mp4"
    if it's not a cache issue, I would need a !small! example file to look into it, since with the files I have here filter_units works fine.
  11. Hey again. thx for the tip, seems not caching issue, also that happened with the new command, I'm uploading the video, and really thank you for the help, it's pretty important for me
  12. you can attach a small sample here,...
  13. Got your file, but got no clue why ffmpeg isn't working.
    What does work is remuxing the whole thing with Hybrid.
    • Start Hybrid
    • open file
    • set "Base->Processing->Video" to "passthrough"
    • set "Base->Processing->Audio" to "passthrough all"
    • set Output
    • Create job
    • Start job
    Upon job creation, Hybrid creates the following calls:
    • to extract the audio
      ffmpeg -y -threads 8 -i "C:\Users\Selur\Desktop\Documentary.mp4" -map 0:1 -vn -sn -acodec copy -map_metadata -1 -metadata encoding_tool="Hybrid 2020.10.29.1" "E:\Temp\iId_1_aid_0_2020-10-29@21_21_35_4010_01.aac"
    • to extract the video
      MP4Box -raw 1 "C:\Users\Selur\Desktop\DOCUME~1.MP4" -out "E:\Temp\Documentary_2020-10-29@21_21_35_4010_02.265"
    • to multiplex the raw streams
      MP4Box -add "E:\Temp\Documentary_2020-10-29@21_21_35_4010_02.265"#video:fps=25:name="UTC 2020-10-28 12:27:35":lang="" -brand hvc1 -add "E:\Temp\iId_1_aid_0_2020-10-29@21_21_35_4010_01.aac"#audio:name="Stereo":lang= -mpeg4 -itags tool="Hybrid 2020.10.29.1" -tmp "E:\Temp" -new "E:\Output\2020-10-29@21_21_35_4010__03.mp4"
    • and the it also creates 3 additional sub-jobs to delete the temp files and rename the output
    MediaInfo reports about the new file:
    mediainfo.exe e:\Output\Documentary.mp4
    General
    Complete name                            : e:\Output\Documentary.mp4
    Format                                   : hvc1
    Codec ID                                 : hvc1 (isom/iso6/hvc1)
    File size                                : 382 MiB
    Duration                                 : 1 h 47 min
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 499 kb/s
    Encoded date                             : UTC 2020-10-29 20:21:46
    Tagged date                              : UTC 2020-10-29 20:21:46
    Writing application                      : Hybrid 2020.10.29.1
    Video
    Format                                   : HEVC
    Format profile                           : Main@L3@Main
    Codec ID                                 : hvc1
    Bit rate                                 : 336 kb/s
    Maximum bit rate                         : 2 543 kb/s
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Standard                                 : PAL
    Bits/(Pixel*Frame)                       : 0.032
    Stream size                              : 258 MiB (67%)
    Title                                    : UTC 2020-10-28 12
    Tagged date                              : UTC 2020-10-29 20:21:51
    Color primaries                          : BT.601 PAL
    Transfer characteristics                 : BT.470 System B/G
    Matrix coefficients                      : BT.601
    Audio
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Codec ID                                 : mp4a-40-2
    Bit rate mode                            : Variable
    Bit rate                                 : 158 kb/s
    Maximum bit rate                         : 202 kb/s
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Stream size                              : 121 MiB (32%)
    Title                                    : Stereo
    Encoded date                             : UTC 2020-10-29 20:21:49
    To lazy to investigate further why ffmpegs bitstream filter doesn't work.
    Cu Selur
  14. Hey mate, I don't know how to thank you for your very great help
    It worked great, perhaps ffmpeg has a bug or is not removing that intentionally!
    Cheers ♥
  15. My guess is that it's a bug.
