I found that there are 3 spline resizers: spline16, spline36, and spline64.
I'm encoding with this command:
The version of ffmpeg I'm using is 4.3.1.Code:ffmpeg -i "infile.mkv" ^ -codec:v libx264 -preset slower -tune film ^ -x264-params level=4.1:crf=23:min-keyint=24:keyint=240:colormatrix=bt709 ^ -vf "crop=1920:816, scale=1280:544:flags=spline, setsar=1" ^ -an ^ "outfile.mp4"
Question 1: For the above command, which resizer was used by ffmpeg to scale the image? spline16, spline36, or spline64?
Question 2: How do I specify, in the ffmpeg parameters, that I want ffmpeg to use the spline36 resizer? Or how can I prevent the use of spline16, and ensure that only spline36 or spline64 will be used?
I think you want to use zscale instead of scale.
http://ffmpeg.org/ffmpeg-filters.html#zscale-1
MeGUI, Spline and Lanczos
By pooksahib in forum Video ConversionReplies: 0Last Post: 18th May 2020, 01:53 -
Best resizer in Avisynth?
By Master Tape in forum EditingReplies: 4Last Post: 1st Jul 2018, 11:19 -
Choosing a resizer with MeGUI
By pooksahib in forum Video ConversionReplies: 6Last Post: 15th Mar 2018, 04:37 -
[MPC-HC (MPC-BE)] Can't change resizer: same output for each resizer
By rqqt in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2016, 11:07 -
SWS Spline/Spline36 filter - Are they the same?
By HelpVid in forum Video ConversionReplies: 0Last Post: 22nd Mar 2016, 07:56
