I have some TV recorded VHS tapes I have been capturing with a Sony SLV-N81 (& DMR-ES15 passthrough). The motor is dying on the VCR.
The picture quality is great on the Sony VCR, and I don't think It would be worth it to buy a S-VHS VCR with a TBC because the tapes I am capturing don't seem be the type that need it most. They play extremely stable and clear, even most EP tapes play perfectly. And the TBC models are just too expensive for the # of tapes I have
But would there be any point to buy a "regular" S-VHS VCR or just buy another standard VCR like I already have? Would there be any real quality improvement going to a S-VHS model without a TBC? (like the JVC HR-S3800/4500/5900). Is there any other kind of regular VHS machine I should buy instead of the Sony N81 again?
Thanks!
				Results 1 to 21 of 21
	Given the background info you've provided, I'm going to say "yes" to the idea your replacement VCR should be a midrange (i.e. affordable) SVHS model. While of course it is almost always preferable to use TBC/DNR models if possible, many people certainly "make do" with decent standard VHS and SVHS models.
 You describe a somewhat unique prior situation which isn't reported that often: apparently your "ordinary" Sony VHS VCR was an exceptionally good example, and played your tapes very well via the ES-15 passthru. Having owned a similar exceptionally good standard VHS model myself for several years, I've experienced the disappointment of it being virtually impossible to replace (chances of finding another "perfect" example thats fully functional are slim to none).
 In such cases, you up the odds of the replacement VCR being satisfactory if you spend a bit more to get the SVHS version: the special S-Video connections that come along for the ride can significantly improve the output of standard VHS playback. Maybe not a night and day difference from when your Sony was working well thru its standard composite video output jack, but SVHS connection will likely be noticeably better than any random non-SVHS VCR you could pick up today.
 Each brand and model series has different strengths and weaknesses, so generally you would pick a compromise design that best suits the majority of your tapes. If you mostly have SP tapes left to transfer, the JVC 5900 series can be very nice. If you still have a significant number of EP tapes left, esp if they're HiFi, look for the Mitsubishi HS-U748 or 749 instead. The Mitsu isn't quite as clean at SP as the JVCs, but has much more reliable and flexible EP tracking.
 Various Toshiba models could rate about the same as your better-than-average example of Sony, but Toshibas were fairly rare in USA/Canada so you don't often see them now at reasonable prices (if at all).
 Midrange Panasonic SVHS can be problematic. Models made before 1996 can be a bit flaky and unreliable today, models made after 1996 tend to have really bad picture quality (oversharpened with a lot of ugly grain). If you can afford the asking prices and (most importantly) find an example in excellent working condition, the semi-pro Panasonic AG-1970 is excellent with EP tapes and about average with SP playback (certainly much better than consumer Panasonic SVHS models, plus it has a weak TBC that can be helpful and adjustable sharpness controls). Panasonic AG-2560 has excellent EP playback picture but just average at SP, very reliable SuperDrive mechanism, but not SVHS. Panasonic AG-1980 is gold standard for SVHS tape transfers, but is very expensive to purchase and maintain, so not for the budget conscious.
 Sony "consumer" SVHS models were almost all unreliable with serious design defects: avoid these today unless you get a VERY good price and can personally test the VCR before purchase.
 If it were me I would go with the Mitsu 748 or 749: these were recent models compared to many others, reasonably priced compared to many others, very rugged and reliable compared to many others, and with much better tracking range than many others. The compromise you make with Mitsu is you aren't going to get truly stunning standard VHS playback, but it will be very good (about the same as a twice-as-expensive, older Panasonic AG-1970). A JVC 5900 etc will arguably be a little less grainy at SP, but will struggle with EP tracking and be less forgiving of HiFi audio tracking errors than the Mitsu 748 or 749. BTW, avoid all other Mitsubishis aside from the 448/449 (VHS) or 748/749 (SVHS): for whatever reason, these particular Mitsu chassis are dramatically more reliable and better at tracking. Be careful also with JVC: 5900 series were decent but some older or newer midrange JVC can be more flakey from a reliability standpoint. Panasonic and Sony "consumer" SVHS tend to be a shot in the dark, not worth the gamble.Last edited by orsetto; 23rd Oct 2020 at 19:58.
	The Sony VCR I could buy another identical one on eBay for between $25-65 and there is tons available in good condition. I'm thinking to go with the JVC. I have a good mix of SP & EP, about 50/50.
 I'm only hesitant to switch models because the Sony I already know how it plays back, the JVC I don't know, I guess I'm just concerned It could be somehow be worse but that probably doesn't make any sense.
	You may have mis-read my point: I wasn't saying you couldn't easily buy an exact replacement model for your Sony SL-VN81, more that you describe your specific example of SLVN81 as working unusually well. This Sony model wasn't particularly known for good picture quality and especially not known for a good range of EP tracking ability: yours may be an outlier, really well-made example. This happened with many models of ordinary, commodity, plain-jane VCR: most of the production run was mediocre with similar performance, but 1 out of 10 would be way better than average. If you lucked out with one of those, and it later broke, chances were you could neither get it repaired back to its original performance level nor find another example that performed as well.
 Current asking prices for the SLVN81 reflect this: it isn't in high demand, so its easy to buy. There's nothing wrong with trying another copy of the same model, you might get lucky and get one close enough in performance to yours that theres no material difference. Just remember, you don't know the history of any VCR on eBay and every VCR wears out in different ways. A replacement SLVN81 might match your SP performance but not EP, or have issues tracking HiFi, or it might be 100% perfectly operational but not have quite as good a picture as your SLVN81 at any tape speed. If you go this route, buy from a seller with no-questions-asked return policy in case you're disappointed.
 JVCs tend to be very good at SP, less so at EP (mostly because the majority of JVC models simply don't track EP tapes made on other VCRs that well). JVC's corporate "flavor" tends more toward smooth, noiseless picture at the occasional expense of some fine detail, midrange Panasonic tends toward more "apparent" detail at the expense of grain and noise (sometimes obnoxiously so), Mitsubishi splits the difference, Toshiba skews closer to JVC.I'm only hesitant to switch models because the Sony I already know how it plays back, the JVC I don't know, I guess I'm just concerned It could be somehow be worse but that probably doesn't make any sense.
 You seem very attached to your SLVN81 picture quality: you may never be comfortable with another brand/model until you try another SLVN81 first. If it works perfect for you, great: you won't have to adjust your expectations at all. But if another SLVN81 proves way off in performance from yours, opt for something entirely different. As mentioned, midrange JVCs do not generally do great with EP tapes recorded on Panasonic or Sony VCRs: since you have a 50/50 mix of SP and EP tapes, you may eventually need to switch from JVC to Mitsubishi or Panasonic just to get steady EP tracking with no static lines. Opting for a model with S-Video connection instead of composite RCA connection typically boosts ability to capture fine details (if the tape has any).
 Sony standard VHS models were much less troublesome than their SVHS models, full stop. You could try a couple different standard VHS Sonys if you feel thats your best bet to match your old Sony, but if you decide to experiment with an SVHS model, avoid Sony. All of their consumer-level SVHS models tended to self destruct at quadruple the rate of their standard VHS models like SLVN81.Last edited by orsetto; 23rd Oct 2020 at 21:18.
	That's very useful information. Well I'll probably just go for the JVC and see how it is. The Sony like you said is a fairly common and standard model so I may just be lucky with the tapes I have, that they play good on it. Or it could be a good example unit.
 Worst case scenario I could return or resell a JVC if its not as good, and then see about finding another good condition Sony one which seems like it won't be too difficult. Thanks for all the useful info. It was hard to find an answer to this from reading other threads because most just recommend going right to the top of the line model, not much discussion I could find about what is the best alternatives to those.
	When discussing units that lack TBC, the ES10/15 is a must.
 I still have some JVC 3800 deck, my workhorse recorders from the 90s.
 Remember, eBay isn't buying, eBay is gambling, when it comes to video gear. Most sellers are clueless, some outright lie. To them, "tested" and "working" means they saw lights on the unit, maybe any sort of on-screen image using a portable TV. It's a pathetic non-test. You must be careful if buying a deck from eBay.Want my help? Ask here! (not via PM!)
	You are mixing up line TBC and frame TBC, While in most cases you don't need a frame TBC unless the tape is crappy, the capture device is crappy, the VCR/camcorder is crappy or a combination of the above, A line TBC in the VCR/camcorder is a must have. Line TBC doesn't correct for tape mistakes, it corrects the playback mechanism mistakes, transporting a tape using wheels and motors is never perfect and causes line jitter, to correct for that the line TBC stores the lines in a buffer (digital memory) and release them in a perfectly timed manner so they all start and end at the same position in the picture raster. An ES15 may correct some of the tape imperfections but will never correct for the tape transport imperfections, It is just impossible.
 As to why S-VHS? Well, it has a better chroma to luma separation, Using S-Video output instead of composite yields better overall picture quality in a form of slightly vivid chroma and slightly sharper luma since there is less interference between the two. While most people don't notice the difference between them, a side by side comparison if provided anyone can see night and day difference.
	I've had very successful captures using the Pinnacle 500-USB with a good VCR and didn't need frame TBC, because there was no V-sync problems with the tape to begin with (If aint broken, don't fix it), Remember while frame TBC corrects only timing it has an effect on the overall picture quality in terms of levels and brightness because of the two process of ADC and DAC it has to go through, I wouldn't want a frame TBC in my workflow unless I have to, or if if it is a lossless process that happens after the signal being digitized and never converts back to analog, which is one of the reasons I no longer use consumer capture cards.
	This is a video enthusiast site: the highest standards are a given, and its almost religion with us to recommend the best possible hardware, software and workflows conducive to top quality results.
 But.
 Read the room. If the OP specifically and deliberately states upfront they are using what many consider a "low end" setup, and they are totally happy with the results they're getting from that setup, but a part of it is breaking down and they want suggestions on how to replace it: not the time to go into our canned spiels about the utter necessity of owning a JVC 9900, Panasonic AG1980, DataVideo TBC-1000, SignVideo, and a piece of Stonehenge "or don't bother".
 The line TBC in the high-end VCRs is almost always joined at the hip to DNR: this combo may or may not be beneficial with every tape and every capture input system. Its ideal to have the feature if you can afford it, sure, but it isn't a panacea: its a tool to be deployed wisely. There will be tape collections that 100% benefit from line TBC, tape collections where each tape is wildly different, and tape collections where none of the tapes are compatible with line TBC and it makes things worse (tearing, distortion). And lest we forget, no "premium" VCR is an island unto itself: many stink at EP tracking, some have overly aggressive line TBCs that cause conflicts with second-gen tapes, etc. There is no magic bullet, just time proven premium VCRs known for the best results in most circumstances. Exceptions abound, and must be dealt with. Budgets intrude, and must be dealt with.
 Same with the external TBC. Vital for some workflows, yet countless laymen never heard of external TBCs, have no idea what they are, and remain perfectly content with their "unstable, crappy" captures. It depends how you're capturing and what your personal standards are: some capture devices are far more tolerant of VHS input than others, to where a makeshift ES15 passthru (or no passthru) may seem adequate to untrained eyes. The results would not fly for professional archival use or commercial work for clients, but if they satisfy the individual and his family who are we to argue.
 And as I've recently discovered after repairing my defunct DataVideo TBC-1000: like attracts like, and mismatches repel each other. The DataVideo TBC needs a certain floor level of signal stability to start with: a reasonably solid midrange to high end tape transport mechanism. If you connect a bottom-feeder consumer grade VHS to a DataVideo, with some tapes the TBC will actually destroy the the video signal instead of improving it (the instability of the VCR overwhelms the TBC circuit). So it isn't necessarily true that simply adding a TBC to an otherwise low-end setup that is currently working satisfactorily will be a massive improvement: half-assing it with random hardware pair-ups can make matters worse.
 And thats just with SP speed tapes: for EP, all bets are off. You may desperately want the benefits of line TBC and DNR for EP tapes, but the Capture Gods may laugh in your face to prevent it. Often, a lower-end VCR will offer noticeably better playback of some EP tapes and you will have to sacrifice that line TBC . Depending on the low end VCR, it might also have a bad interaction with an external TBC, at which point you may need to use an alternate capture device that is far less persnickety and can function without TBC mediation. The tape will always dictate what capture method will succeed with it (whether that method meets our technical standards or not). The default recommended workflows for best quality work great, until they don't.
 Starting from scratch with no capture gear at all yet? Got the means to afford a fairly significant temporary investment in gear you can later re-sell for about 70% of what you paid? Then absolutely: go with the standard, default recommendations here as far as hardware and software workflow. These recommendations have been tested and proven to give repeatable, reliable (if not always 100% consistent) results over many years. Depending on your tapes, compromises and exceptions to the "rules" may occur, requiring counterintuitive workarounds. But by and large the default recommendations became defaults because they work best most of the time.
 OTOH, if you've been using a simple low-end capture system that has been working fine for you, you haven't encountered any major glitches, your family/friends don't complain about the quality: perhaps stay the course and don't rock the boat. If something breaks down, replace it exactly and keep going. There really isn't a middle ground in VHS capture: you're either satisfied with the results from a lower end, less sophisticated system, or you're not. If you're not, prepare to dive whole hog into a much more expensive, more complicated way of working. Proper research and careful, educated buying of often-pricey used gear will be required. A piecemeal, random approach often fails or disappoints: pull together the recommended components as a complete setup to deliver the expected performance.Last edited by orsetto; 24th Oct 2020 at 12:54.
	I think that's a good point. It's not all or nothing.
 The main reason I don't want to spend the extra for the higher end models is because the playback of the tapes I have don't seem like they would benefit hugely. I have certainly seen tapes that would it seems benefit from a line TBC more, but the ones I need to capture, the ES-15 makes them very stable with little noise or horizontal movement of the details. Even EP tapes. Then with QTGMC and other processing they come out as excellent clear files.
 If I had worse tapes I would buy a TBC model, but I think for my tapes specifically it would be a lot of money for a very small improvement. Plus it is risky buying a $300-500 VCR, if it breaks that's a lot more of a loss than a $50 or $100 model.
	My AG-2560 has problems loading and ejecting. I am not good mechanically so I will not attempt repair. I am transferring my VHS-C home videos. I am debating weather or not to go with the AG-1970 or another AG-2560. Most of my tapes are in SP. I have read that the S-video is better than the composite rca that I have to use with the AG-2560. In your opinion would I go with the AG-1970 or the AG-2560 for best picture quality?
	As it happens, I recently had reason to closely compare my AG1970s to my AG2560s for a project. Most of the comparisons were to identify the best deck for transferring a subset of tricky SLP/EP tapes, but I did also re-check some SP tapes. IMO, playback performance is a draw between the two models (assuming both in excellent working condition). While the 1970 is a more sophisticated design, the 2560 is over a decade newer with streamlined electronics and less fussy transport. Even with the 2560 limited to composite connection only, it runs neck and neck with the 1970 using its SVHS output for standard VHS SP playback.
 Market conditions must also be considered. The 1970 is quite old now, and tended to be purchased by event videographers who used them heavily. While plentiful and common, it has gotten more difficult in recent years to find a 1970 in really good condition. The less-common, much newer 2560 was not typically used as heavily and has more durable electronics (tho the transport isn't as sturdy as the 1970 version). The 2560 is the boring, sensible choice, the 1970 the fun semi-pro deck with dozens of switches and buttons to play with, but for playback they're too close to call a definitive winner. Individual sample variation and the tapes you want to play in them will be more significant factors.
 Both models are currently overpriced in the secondary market given their performance envelope, easily double or triple what they sold for just two or three years ago. They are good, reliable, midrange VCRs but not exceptional enough to justify current inflated eBay asking prices. The 1970 in particular is often misleadingly pitched as an alternative to the very expensive, flakey, high-performance AG1980: they are not comparable. Externally identical, but the 1980 has completely different electronics and mechanics (far less reliable than the older 1970, but capable of notably better playback picture). At $80 to $100 mint condition, the 1970 can be a reasonable choice, but it is absolutely not worth the current $250 - $350 being asked. Logical eBay sellers might take sensible offers, otherwise hunt locally for bargains.
 Load/eject breakdowns are an unfortunate fact of life as many VCR models age. Few models are worth the cost of repair (if you can even find a qualified tech willing to do the work anymore). The 1970 is arguably easier for skilled techs to repair, as the loader and transport were designed to be serviced with replaceable parts. The 2560 is a more sealed-box design, less conducive to repair: if you prefer the 2560, replacing it with another better-functioning example may be more cost-effective than repair.Last edited by orsetto; 17th Apr 2021 at 23:35.
	Thanks orsetto. I am torturing myself as I tend to do with purchases. I may go for another 2560 since I am so familiar with it. They are much more reasonably priced than the 1970's. I see a person locally that has a Panasonic S-VHS PV-S7670. I know nothing about some of these Panasonic svhs lower priced units. He wants $100. Are there any other units you would recommend under the $200 and preferably around $100? Since I shot with a Panasonic camcorder I think I want to stick with Panasonic.
	I bought a 7670 brand new and absolutely hated its playback. It dates from the "dark time" when every VCR mfr inexplicably decided indiscriminate detail boost would be embedded as a non-defeatable feature (except JVC, which true to form went in the opposite direction toward blur). The image from a 7670 is best described as 70% sharpened luma noise with traces of a recognizable picture struggling to punch thru the noise. Truly ugly, and definitely not worth $100 used.
 Shopping second-hand Panasonics can be a challenge nowadays due to the bipolar swings in Matsushita's design ethos from year to year (and sometimes model to model in the same year). The prosumer AG models were a stabilizing force, bridging several of these swings (i.e. the "obsolete" 1970 is noticeably better than almost all their consumer models sold after 1996, while the 1980 remains a high water mark among all VCRs, period). The 2560 could be considered a feature-stripped non-SVHS spin on the 1970. In the consumer lineup, the last decent series was the mid-90s 46xx (particularly the higher-end VHS and SVHS with DynAmorphous Metal Heads and undocumented color noise reduction circuit).
 In the $100 price range today, I would probably skip dealing with the vagaries of aging Panasonics and head straight for the circa 1999-2001 Mitsubishi HS-U448 or 449 (standard VHS) or 748/749 (same chassis with SVHS). Very sturdy, well-built, reliable decks with excellent wide tracking range for SP, EP and HiFi audio: playback on par with an AG1970, but much newer, less expensive and easier to find in good condition. These four Mitsus fly under the radar because they were preceded by several iterations of unreliable, mediocre VCRs using an older, more fragile chassis (by the time Mitsu finally did a complete redesign, VCRs were already being pushed aside by dvd players). Sort of a "stopped clock is right twice a day" history: these four midrange Mitsus were very good, and were followed by the final, excellent HS-HD2000U DVHS with TBC/DNR, but every other Mitsu before them was dodgy.Last edited by orsetto; 18th Apr 2021 at 00:38.
	Thanks again. Is there a good place to research vcr models? I don't want to keep coming on here and bugging with questions. I have been looking and I do see other models of Mitsubishi like the HS-U790 svhs, but without knowing if these are good maybe just stick with the model numbers you listed? I don't want to get too stingy and go with a bad unit, just don't want to go over the $200 mark for financial reasons. Of course I could always resell once project is completed I guess.
	I picked up a used HS-U748, unfortunately mine developed a RW/FF problem where it just runs out of energy,
 looks like it struggles, and often stops before it gets to the end of the tape.
 Not familiar enough with the chassis to diagnose the problem (yet).
 Except for that, it's a great VCR
	Is it good to do the work on a VCR that is the same brand as the camcorder that was used to record? Example mine was a Panasonic VHS-C camcorder. Would it be best for my work to be with a Panasonic VCR? Or does that even matter?
	Of course any VCR can break, but its relatively uncommon for the fairly recent Mitsus I mentioned to fail. I've heard of failures similar to davexnet's 748 once or twice over the past few years: I think it traces back to whatever modulates FF/REW speed from one end of the tape to the other. These decks have super-ultra-fast FF/REW that packs the tape reels very evenly and smoothly, but it "gearshifts' a couple times (slow at beginning, ultra-fast in the middle, then slowing again as it nears the front or end of the tape for auto-stop). I seem to remember it wasn't that hard to fix, but can't recall the details.
 Using the same brand of VCR that made the tapes is generally a good idea, but there are loads of exceptions to that rule so its more theoretical than practical. A shocking number of VCRs drifted off nominal recording spec months after purchase, so theres no guarantee either the original VCR or the "identical" one you buy today will match. VHS-C camcorders were a wacko Rube Goldberg adaptation: the mechanism is so different from standard VCRs that same-brand compatibility is usually moot. The "advantage" of using same brand/model for capture is solely based on hopes of optimal, matched tracking: this doesn't work out in reality as often as you'd expect. Your chances for a good video and/or HiFi tracking match are better with any random VCR model that has a long history of broad compatibility than from using the same brand/model that made the original tapes. Panasonic 1970 / 1980 or Mitsubishi 448/449, 748/749 are more likely to solve tape tracking issues than any other option.
 There aren't any sites I'm aware of that go into any useful depth about "ordinary" VCRs. VH and DigitalFAQ tend to specialize in the nitty-gritty details of premium SVHS models with TBC/DNR to the exclusion of anything else, because these are preferred by most dedicated capture enthusiasts. Apparently, there are far fewer of us with specific need for alternate plainer VCRs to handle certain tapes, and if you're on a tight VCR budget the prevailing attitude seems to be "don't bother with capture at all". So if you have questions, ask them wherever you can find any answers.
 Re Mitsubishis specifically: very easy to choose among them. The only models worth considering today are 748, 749, 448, 449, and the one-off DVHS HS-HD2000. The first four were good consumer grade decks of much better than average redesigned build quality considering how late they were mfd (i.e. by this point Panasonic had totally thrown in the towel and was selling utter garbage VCRs made in China). All four Mitsus are the same basic VCR, with x49 being a year or so newer than x48 and models beginning with 7 being the SVHS version. All four are very forgiving of video and HiFi tracking issues: they are the go-to choice when you encounter tapes with tracking problems.
 The Mitsu DVHS is a separate case: it was based on the older SVHS 790 chassis but added the DVHS feature plus TBC/DNR derived from JVC's circuit (the only Mitsu to ever include TBC/DNR). The DVHS does not have the exceptional tracking range of the other four: its as twitchy and temperamental with HiFi and EP as many JVCs, plus its burdened with the older 790 chassis. The Mitsu DVHS is an alternative backup to my JVCs: IMO, it has a nicer video output from the TBC/DNR and better linear audio playback of non-HiFi tapes.
 All other older Mitsubishis are risky and should be avoided, the 790 for sure. From approx 1995 thru 2000, MGA made multiple versions of lookalike VCR with varying features (SVHS yes/no, flying erase head yes/no, cable box control yes/no, etc). All are prone to catastrophic loading mechanism failure that cannot be repaired: the parts are made of a fragile plastic that slowly decays, eventually fracturing into pieces. The playback performance for capture is also mediocre: like the Panasonic 7670, these mid-90s Mitsus are skewed toward a "sharpened noise" presentation. Even older Mitsus can still be found on eBay, they are interesting but also poor risks. Playback is just average, reliability suspect, and parts unobtainium (similar to the Sony SVHS history).
 Other brand VCRs can be very decent, the trick is to find them in working order at reasonable cost. Many Sharps punch above their weight. Toshiba made some really good VCRs with interesting variations of noise reduction and head design before they gave up and subcontracted everything to Funai China. Hitachi made a number of top quality VCRs under contract to other brands, Canon relabeled a couple of nice Panasonic AGs, Sony offered two or three exceptional SVHS models among their sea of crap. Panasonic, Sony and JVC made a few really interesting, end-of-era big "pro" SVHS. The problem most of these now face is age and lack of available repairs: if you can find them for peanuts, you can use them til they break, but spending serious coin on one would be a mistake.
 There's a reason serious VCR discussion has dwindled to just a handful of JVCs, Panasonics and Mitsubishis: they either have the TBC/DNR feature, or exceptional tracking, or good reliability/repairability, or some combination of those factors. If you're gonna gamble on something that might need repairs, it pays to stick with a model known to be worth the trouble/expense. Everything else should be considered disposable, the price you're willing to pay limited to what you can afford to take as a dead loss.Last edited by orsetto; 18th Apr 2021 at 17:22.
	Last question would be if the s-vhs with s video will make a difference. If so I will probably be patient and go with a
 s-vhs.
 I think I will probably go with one of the Mitsu's you mentioned. I see one 748 on eBay (eBay always makes me nervous) and quite a few of the 448's. I will try to find someone who might be a one owner with a good reputation. My VHS-C tapes have played remarkably well in the past and they are standard VHS.Last edited by coffeeboy; 22nd Apr 2021 at 14:55.
  VCR buying guide (S-VHS / D-VHS / Professional)By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 06:10
  How do I fix this on my VHS VCR?By Etcetera in forum RestorationReplies: 13Last Post: 12th Dec 2019, 23:29
  VHS conversion which VCR is better?By RS456 in forum Capturing and VCRReplies: 11Last Post: 28th Feb 2019, 08:56
  VHS-C won't play in VCRBy abydos71 in forum Newbie / General discussionsReplies: 3Last Post: 15th May 2017, 14:03
  VHS tape got stuck in VCR, now VCR plays full staticBy Rand251 in forum Newbie / General discussionsReplies: 21Last Post: 4th Apr 2016, 10:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
