I just downloaded a 700MB DivX DVD Rip of Down to Earth and used TMPGenc to encode to MPG. What I got was a 2GB file. How do I put that into 2 VCD's? When I converted it I got no sound either. Is ther enayway of bringing the size down?
Please help, I would like ot put it into 2 CDR's for VCD.
2 gig is too big for standard VCD 2.0; u must've made a SVCD or some sort like it
Nooo,
SVCD will only make it bigger.....
Just use TMPGenc to cut the files to parts of 74/80 minutes and burn them on 74/80 mintutes cds.
So you'll need 3 CD's instead of 2. But it will play.
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
How do you configure TMPGenc to break the large file up into two or three 74/80 minute pieces? Also what happens when the first vcd is played in a player and it gets to the end of the cd? Will you be prompted to insert the 2nd cd?
Hi,
Just start TMPGenc and select "MPEG Tools" from the File pull-down menu. Select the "Merge and Cut" tab and add a file you wanna cut. now select the format your using in the selector above (VCD,MPG, MPG2 etc.) By double clicking the file you can set the start end which to save.
Greetz,
pSyChO dAd
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
At TMPGenc configure, goto Advance tab and double click at " Source frame range". There you can set frame range to fit in one CD (you have to encode twice if you wanna split one movie into two CDs. Also check Sefy's Guide.
Episodic DVD Rip Question
By Eternal7331 in forum DVD RippingReplies: 14Last Post: 18th Nov 2013, 19:36 -
Conversion Question: rmvb file via dvd player
By seifhatem in forum Newbie / General discussionsReplies: 5Last Post: 17th Nov 2010, 11:01 -
Framerate conversion question (AVI --> DVD)
By kmmoore in forum Video ConversionReplies: 3Last Post: 19th Oct 2007, 09:47 -
NEWBIE QUESTION about dark passages in a DVD rip
By pbecks in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2007, 07:50
