Hi,
The Ultra Video Group has posted some new test videos that I would like to use for my Ice Lake QSV tests, the problem is that they are in YUV RAW format and I can't use them in Linux, none of the video players or video editors will play them.
I tried converting them to Y4M using ffmpeg but even though the conversion seems to go fine and media info seems to show them as proper Y4M files, when I try to open them with any editor they won't open and when I try to play them back with any player, like smplayer, vlc or totem, all i see if a green garbled mess with lines all over the pace, basically a corrupt picture.
Below is the link, I'm talking about the samples that begin with City Alley and have the following characteristics:
Original Footage:
Resolution: 4096 x 2160 pixels
Frame Rate: 50 fps (progressive)
Subsampling: 4:4:4
Bit depth: 16 bit
Data format: RAW
http://ultravideo.cs.tut.fi/#testsequences
-Thanks
Maybe you entered the wrong resolution or pixel format?
Original recording was 16bit 4:4:4, 4096 x 2160 (4K), linear RAW, but the provided format is 10bit 4:2:0, 3840x2160 (UHD), YUV
Code:ffmpeg -r 50 -s 3840x2160 -pix_fmt yuv420p10le -i input.yuv -strict -1 output.y4m
Converting Blu-Ray YUV to RGB and back to YUV?
By killerteengohan in forum RestorationReplies: 17Last Post: 17th Mar 2020, 21:42 -
Help Converting YUV to RGB
By chris319 in forum Video ConversionReplies: 7Last Post: 24th Sep 2018, 19:51 -
YUV to RAW Conversion with vsrawsource in avisynth
By jindadil007 in forum Video ConversionReplies: 4Last Post: 6th Feb 2017, 13:45 -
What difference output .yuv and input yuv (based on h.264 jm)
By Aaron_2992 in forum ProgrammingReplies: 2Last Post: 7th Sep 2016, 10:12 -
Converting Between 10-bit RGB and YUV and Back
By chris319 in forum Video ConversionReplies: 22Last Post: 9th Jul 2016, 00:53
