First off let me say I don't think anything I am writing here promotes piracy or is illegal.
So I bought a "UHD friendly" LG WH14NS40 blu ray drive. It is internal and I use a SATA to USB converter.
This is the information according to MakeMKV
Drive Information
OS device name: E:
Current profile: BD-ROM
Manufacturer: ASMedia
Product: ASM105x
Revision: 1.02
Firmware date: 2115-12-11 15:03
Bus encryption flags: 17
Highest AACS version: 61
Now here's what happens. I put in a 4K disc. It reads. So far so good. But I just leave it in my drive, do nothing else for a few minutes except maybe browse the contents via Windows Explorer, and it freezes, the light keeps flashing, it makes the scratch sound, essentially the drive treats the disc as if it's trying to read a bad disc. I have to eject to free it up. Then I close the drive and it reads it again. And like clockwork it does it again after a few minutes.
Here' a video with what it does: https://drive.google.com/file/d/1I4gpKDUDbpfXduVJ9OusxgnosSMoM-kO/view
I had an old laptop with Windows Vista. Plugged the drive to that, same thing. So that eliminates any issues with my PC.
This only happens with 4K discs. I tried two different 4K discs and same thing. I tried with a regular blu, and this did not happen. Tried with a DVD and CD did not happen.
Here's the kicker though. If MakeMKV is running, it takes MUCH longer for this to happen. Like, if I weren't trying to test it I probably wouldn't realize it. To boot, I was able to rip 4Ks twice with MakeMKV no issue.
If I leave it idle with MakeMKV open it will happen again eventually though and I will have to eject the disc.
Now upon a little more research I came across this in another forum and it describes my issue exactly:
So my question is, has anyone here had that issue? Did you use that solution? Did it work? Any other suggestions?Sleep Bug:
All UHD Friendly drives have the sleep bug, this is when a UHD disk is left idle in the drive for 2 minutes. Once the drive goes to sleep, the UHD Friendly drive will no longer be able to read the disk without opening and closing the disk tray and will make horrible seeking noises until this is done.
Sleep Bug Fix:
To fix the sleep bug on a UHD Friendly drive flash firmware from an UHD Official drive like WH16NS60 DE 1.00 or 1.01MK
IMPORTANT Before you flash:
1. Make sure your Drive was built after 2015
2. Drive Platform MT1959<Most important
3. SVC NS50+ LG only
4. Just because your drive is the same model number does not mean it will work, if you are unsure ask me i offer remote flashing and check everything before i flash.
5. Dont flash your dive if it does not meet these requirements if you do you will be unable to read all disks and unable to restore without dosflash that does not work on most modern computers
Results 1 to 9 of 9
You will need to update the bios if you haven't already,it's been stated they won't read 4k uhd disc out of the box.
as far as i can tell the only lg drive to support 4k uhd is the WH16NS60
Yes, you got your advice from MakeMKV's forum. Not only that but certainly there are fewer VideoHelp posts about ripping UHD Blu-ray than posts on the same topic at the MakeMKV forum. In light of this doesn't it make more sense to ask there if you want to know if the advice posted in their forum will work to fix the "sleep bug" for your LG WH14NS40?
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I have one, and yes, it's an LG drive that officially supports UHD Blu-ray playback with PowerDVD Ultra. However, even this drive cannot be used for ripping UHD Blu-ray unless it's flashed with modified firmware which allows that. I have not flashed my drive because I am not interested in ripping my UHD Blu-ray collection.
Class316 is asking about a UHD friendly drive, one that supports reading BD-R XL but lacks other features that are required for UHD Blu-ray playback with software licensed by the BDA.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
see this post - https://www.makemkv.com/forum/viewtopic.php?t=22232
and this post - https://makemkv.com/forum/viewtopic.php?f=19&t=19292 -
You are correct. It reads everything and I can rip 4K via MakeMKV. After all the research I decided this would be the best solution for me.
I'm afraid to flash it since it is largely doing everything I need it to.
I am able to
read and rip 4K movies and play them no issue
read and play CDs, DVDs, and regular blus
Maybe I'll just leave it alone.Last edited by Class316; 23rd Oct 2020 at 02:07.
Bug: Potplayer "maximize" click turns to full screen and hides taskbar
By mayheamk in forum Software PlayingReplies: 3Last Post: 28th May 2025, 02:26 -
Will a JVC VCR "Stop" Playback if the video is "too grainy" or degraded?
By timepassenger in forum Capturing and VCRReplies: 8Last Post: 2nd May 2020, 07:17 -
Any Google Drive "addon" for MPC-HC?
By stranno in forum Software PlayingReplies: 0Last Post: 11th May 2019, 13:55 -
Why x264 "placebo" preset produce bigger file than "very slow"?
By aleaksunder in forum Video ConversionReplies: 21Last Post: 2nd Mar 2019, 07:25 -
how to "eject" the drive unit using a command prompt?
By marcorocchini in forum Newbie / General discussionsReplies: 16Last Post: 27th May 2018, 22:37
