I don't understand how to use the program. Should I be using "eac3to 3.34 with UsEac3to GUI 1.3.0 Portable"?
I've got 30fps MKVs with AAC audio. I need to slow down the audio to 29.97 fps and change the sample rate to 48000 (do I also need to change the pitch as well?). Preferably I would like to be able to just drag a folder of MKVs into the program to batch process them or I could drag a folder of AAC files into the program.
How do I do that? Would it be possible to make a batch file to do that?
Sample video is here: https://forum.videohelp.com/attachments/51200-1577216790/TrimSample.mkv
That only seems to be able to process one file at a time. I need to process a folder of files.
how can I mux 25 fps audio into 23.438 fps (1024 spf) ?
By precipizio in forum AudioReplies: 12Last Post: 16th Apr 2020, 14:06 -
convert an audio track from 24 to 23.97 fps with Audacity
By Alice in forum AudioReplies: 2Last Post: 6th Mar 2019, 09:51 -
convert an audio track from 23.97 to 29.97 fps with Audacity
By Alice in forum AudioReplies: 3Last Post: 6th Dec 2016, 20:01 -
Convert 51.43 fps video in 59.94 fps container to straight 50 fps video
By mr_lou in forum Video ConversionReplies: 5Last Post: 8th May 2016, 11:47 -
convert 30 fps time lapse video to 60 fps to speed up and keep all frames
By acem77 in forum Video ConversionReplies: 12Last Post: 19th Jan 2016, 20:01
