  1. I have messed around with some Blu Ray authoring, but really want to get into it.
    I will have lots files that are mkv, and need to make them into blu rays with simple menus.
    All i really want to do in the menus is change the background, be able to pick each file, and add some background music.
    What is would be a good simple program to do all of that in?
  2. Originally Posted by Loplop View Post
    https://www.videohelp.com/software/TMPGEnc-Authoring-Works
    used it loads of times to make DVD's,AVCHD discs and Bluray discs,really easy to use
  3. When i went to the webstie to look at TMPGEnc, it's only for 64bit machines now. I have a 32 bit...so no luck
