I saw this section and figured "Hey, I'm a Newbie..."
I downloaded TVDownloader and YouTube-dl-gui and I have the same question about them both, and they do the same thing I'm asking about. Regardless of what setting I choose for the Video Resolution / Quality, they both download the best video available. I chose 720p in both programs, but the downloads are 1080p. (If 1080p is available, of course.) Is there a way to force them to download in 720p?
Thanks in advance!
Ax
Hi Ax,
Some resolutions may be unavailable, as far as I know. The average list of possible resolutions must be like this:
Best, 1080p, 720p, 540p, 480p, 360p, Worst.
I'm still using TVDownloader for educational purposes and pimion speech recognition from videos.. I had to update it manually. What I did exactly: replaced the youtube-dl.exe file in C:\Program Files (x86)\TVDownloader with the latest version: https://youtube-dl.org/downloads/latest/youtube-dl.exe -
@Axel Slingerland
If you just need to download audio/video you can try PyIDM: https://www.videohelp.com/software/pyIDM . It's a good GUI for youtube-dl.exe and youtube-dlc.exe and it gives you an option to choose many qualities of videos and audio. Make sure the first one is set as the main engine (it's updated more often at the moment). After starting the program always manually check for update in Settings - Update. Easy way to have the newest version of the program or youtube-dl/c installed.
It's a bit late response, but maybe someone will find PyIDM useful. -
Use "youtube-dl -F URL" to get a list of available streams. Then use "youtube-dl -f VID+AUD URL" to get the streams you want. VID is the name of the video stream as seen in the first command line, AUD is the name of the audio stream. This always works unless the particular stream isn't available or is mislabeled.
Code:C:\Youtube-dl>youtube-dl -F https://www.youtube.com/watch?v=kGwUovgcxB4 [youtube] kGwUovgcxB4: Downloading webpage [info] Available formats for kGwUovgcxB4: format code extension resolution note 249 webm audio only tiny 55k , opus @ 50k (48000Hz), 2.70MiB 250 webm audio only tiny 71k , opus @ 70k (48000Hz), 3.39MiB 140 m4a audio only tiny 130k , m4a_dash container, mp4a.40.2@128k (44100Hz), 7.39MiB 251 webm audio only tiny 138k , opus @160k (48000Hz), 6.71MiB 394 mp4 256x144 144p 90k , av01.0.00M.08, 25fps, video only, 4.11MiB 278 webm 256x144 144p 97k , webm container, vp9, 25fps, video only, 5.15MiB 160 mp4 256x144 144p 110k , avc1.4d400c, 25fps, video only, 3.54MiB 395 mp4 426x240 240p 204k , av01.0.00M.08, 25fps, video only, 7.34MiB 242 webm 426x240 240p 223k , vp9, 25fps, video only, 9.02MiB 133 mp4 426x240 240p 244k , avc1.4d4015, 25fps, video only, 6.95MiB 396 mp4 640x360 360p 388k , av01.0.01M.08, 25fps, video only, 13.25MiB 243 webm 640x360 360p 410k , vp9, 25fps, video only, 16.84MiB 134 mp4 640x360 360p 632k , avc1.4d401e, 25fps, video only, 18.84MiB 397 mp4 854x480 480p 688k , av01.0.04M.08, 25fps, video only, 23.15MiB 244 webm 854x480 480p 756k , vp9, 25fps, video only, 29.46MiB 135 mp4 854x480 480p 1157k , avc1.4d401e, 25fps, video only, 38.34MiB 398 mp4 1280x720 720p 1362k , av01.0.05M.08, 25fps, video only, 47.44MiB 247 webm 1280x720 720p 1519k , vp9, 25fps, video only, 60.10MiB 136 mp4 1280x720 720p 2312k , avc1.4d401f, 25fps, video only, 73.08MiB 399 mp4 1920x1080 1080p 2494k , av01.0.08M.08, 25fps, video only, 84.58MiB 248 webm 1920x1080 1080p 2675k , vp9, 25fps, video only, 107.58MiB 137 mp4 1920x1080 1080p 4333k , avc1.640028, 25fps, video only, 134.23MiB 18 mp4 640x360 360p 575k , avc1.42001E, 25fps, mp4a.40.2@ 96k (44100Hz), 32.85MiB 22 mp4 1280x720 720p 1409k , avc1.64001F, 25fps, mp4a.40.2@192k (44100Hz) (best)
Code:C:\Youtube-dl>youtube-dl -f 136+140 https://www.youtube.com/watch?v=kGwUovgcxB4 [youtube] kGwUovgcxB4: Downloading webpage [download] Destination: Jeremy Wade Catches The World's Most Venomous Animal By Hand! _ River Monsters-kGwUovgcxB4.f136.mp4 [download] 100% of 73.08MiB in 00:17 [download] Destination: Jeremy Wade Catches The World's Most Venomous Animal By Hand! _ River Monsters-kGwUovgcxB4.f140.m4a [download] 100% of 7.39MiB in 00:01 [ffmpeg] Merging formats into "Jeremy Wade Catches The World's Most Venomous Animal By Hand! _ River Monsters-kGwUovgcxB4.mp4" Deleting original file Jeremy Wade Catches The World's Most Venomous Animal By Hand! _ River Monsters-kGwUovgcxB4.f136.mp4 (pass -k to keep) Deleting original file Jeremy Wade Catches The World's Most Venomous Animal By Hand! _ River Monsters-kGwUovgcxB4.f140.m4a (pass -k to keep)
MediaInfo report on the downloaded video:
Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 7 min 58 s Bit rate : 1 278 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.055 Stream size : 72.9 MiB (90%) Title : ISO Media file produced by Google Inc. Writing library : x264 core 155 r2901 7d0ff22 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC
TVDownloader 1.18 and 1.19 problem
By gingerdreadman in forum Video Streaming DownloadingReplies: 0Last Post: 9th Sep 2020, 09:11 -
Download from Mixcloud using Youtube-dl-gui?
By zeus182 in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Jul 2020, 12:52 -
MacYTDL – youtube-dl GUI for Apple Macs
By MacYTDL in forum MacReplies: 17Last Post: 15th Mar 2020, 20:57 -
TVdownloader ETAERROR
By stijntje in forum Video Streaming DownloadingReplies: 1Last Post: 9th Mar 2020, 07:38 -
Questions/issues with youtube dl gui 1.63
By zeus182 in forum Video Streaming DownloadingReplies: 0Last Post: 18th Feb 2018, 21:02
