I am wondering why those frames are dropping on me while using the MMC 7.6
I am running WinXP Pro, PIII 800 512MB of RAM 40GB HD 7200rpm ATI Radeon AIW 32MB DDR
Have you tried shutting down your virus scan and any other programs that are working in the background prior to capturing? I know with my system, that is the problem 98% of the time.
My shameless plug - XavierEnterprises.net -
Are they dropping right at the start of capture, or regularly thoughout? Right click on the "% frames dropped" and select the option to show total frames dropped - this will tell you if the drops are just a starting "cough" or a constant affliction.
Another question; what is your CPU utilization % when capturing? If this gets really close to 100%, drops are likely to occur.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 05:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 22:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 13:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 20:59
