Hi everyone!
I have been using a DVD/VHS Combo unit for my captures. Today I was about to capture yet another tape, but something was strange on that tape. While I could see something was recorded on it, the picture was very un-stable. So I followed a tip I was reading here and worked in the past - I was fast-forwarding the video all the way forward, and then re-wind to the start. That indeed fixing the video, but my audio got all muffled. I can hear it, but the hiss is strong then the actual audio (and the audio is muffled). I tried to clean the Audio head, but that didn't solve the problem for me. What just happened? I didn't change any settings in the Video itself (I even tried to play around with the settings fixing it), and I tried another Capture software other then VirtualDub just to check I didn't missed up the configuration. Still there. Any ideas?
EDIT: tried a different VHS combo unit. Sound is fine. So it was something specifically with this unit. Opened it again, cleaned other sections - and not just the Audio head (Video head, some other recommended section). Didn't work. I let the VCR sit for a while out of electricity like it sometimes help to Computer. Everything back working after 30 minutes. Was it the cleaning? Idle time? no idea
Feel free to remove this topic - as I can't![]()
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Your tape may have some mold that had build up around the audio head, Cleaning several times with alcohol and a soft pointy tip will clear the stationary head, Such build up could be hard to remove with alcohol sometimes, I've had to use a wet tip soaked in WD40 to loosen it and finish cleaning it up with alcohol.
Sudden problem with VidCoder
By rad2791 in forum Video ConversionReplies: 1Last Post: 11th Aug 2020, 12:58 -
can't record audio all of a sudden (Sound Forge, Audacity, Vegas Pro 16)
By clashradio in forum AudioReplies: 3Last Post: 8th Jul 2020, 23:32 -
How To Fix Muffled GoPro Audio
By blewyn in forum AudioReplies: 2Last Post: 6th Mar 2020, 00:00 -
why is HCENC being so slow all of a sudden?
By DaneClark in forum Authoring (DVD)Replies: 24Last Post: 16th Jul 2017, 08:31 -
Darkened image all of a sudden
By Kingsy in forum Software PlayingReplies: 5Last Post: 7th Apr 2016, 12:54
