say you have a video that is 640x480 and 25fps and you render it in 1280x720 and 30fps will that distort the video and lowers the quality? is it best to keep it as the original format?
640*480 is native 4:3. 1280*720 is native 16:9. So going from the first to the second will stretch/distort the video.
If you want to upscale 4:3 then you would chose 960*720
Generally, any additional render will lower actual quality. You would have to increase the bitrate to compensate for the larger image but real quality is still lost. -
Simple answer is YES to both of your questions.
640x480 -> 1280x720 stretches the video horizontally (4:3 -> 16:9), unless you add borders and/or force the display aspect ratio and set the sample aspect ratio correctly (assuming that your playback device can handle it properly).
25fps to 30fps speeds the runtime up and may desync video and audio unless you telecine or interpolate it properly.
So yes, it is often best to keep it at the original format unless you know exactly what you are doing.
Of course you can always try and see what you get
change the very low resolution of video to high resolution
By idi0t in forum Newbie / General discussionsReplies: 22Last Post: 1st Jul 2017, 10:51 -
Current state of Youtube audio? Quality not related to video resolution?
By brassplyer in forum Video Streaming DownloadingReplies: 1Last Post: 16th Jun 2017, 15:42 -
any software to increase the quality (resolution) of a movie
By tesoke in forum Newbie / General discussionsReplies: 10Last Post: 25th Nov 2016, 13:22 -
Resolution, Bitrate and Quality
By JonNorway in forum Video ConversionReplies: 12Last Post: 19th May 2016, 15:24 -
Improve blurry low quality video into clear high quality video.
By Osram123 in forum Video ConversionReplies: 2Last Post: 4th Apr 2016, 02:48
