I have damaged .AVI file from my dashcam which i want to join in solveigMM video splitter but it won't open in solveigMM . if it did i could cut the piece i want and that would be a new file so may be ok. The damaged file plays in VLC so i did a screen record with camtasia which says it saves as an AVI if you don't need sound i think it is. i don't need sound. But the AVI from Camtasia is not compatible. Neither is one from aimersoft video converter
can I repair an avi. It is only 2 mins and i only want tens secs. This is the media info from the corrupted file
Anyone had any experiece with this https://www.risingresearch.com/en/dvr/ i see people use it here, i got a low risk warning from AV
General
Complete name : C:\Users\MY DASHCAM FILE\
Format : AVI
File size : 284 MiB
Duration : 2 min 3 s
Overall bit rate : 19.3 Mb/s
Video
Format : JPEG
Codec ID : MJPG
Bit rate : 18.0 Mb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.652
Stream size : 266 MiB (93%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 512 kb/s
Channel(s) : 1 channel
Sampling rate : 32.0 kHz
Bit depth : 16 bits
Stream size : 7.54 MiB (3%)
Alignment : Aligned on interleaves
Results 1 to 20 of 20
What is it you're trying to do? In the first post you said you're trying to join (to another file?)
then later you said you're trying to extract 10 seconds -
First of all, try opening the problem file in Avidemux and see if it will let you save the seconds you want,
leaving video and audio at copy (on the left).
If it does you can append the new file and the second file in the same program -
That bad file shouldn't be hard to deal with. MJPG is an all intraframe codec. You should be able to open it with VirtualDub, select Video -> Direct Stream Copy, then save it as a new AVI. That will rebuild the keyframe index. Or use fmpeg to remux it.
But you won't be able to simply join it to other AVI files unless they also use MJPG video and PCM audio with the same properties (frame size, frame rate, sampling rate, bit depth, etc.)Code:ffmpeg -fflags +genpts -i input.avi -c copy output.avi
The file is only 19 MB. Why don't you just upload it here and someone will take a look at it. -
vlc media player has a built in video repair feature - https://www.stellarinfo.com/article/repair-AVI-video-file.php
AMR file repair/recovery
By AMR in forum AudioReplies: 1Last Post: 5th Dec 2020, 20:28 -
ASF video file repair
By chipsang in forum Newbie / General discussionsReplies: 6Last Post: 18th Oct 2019, 02:02 -
Read and repair broken MPEG/AVI file
By aq_swe in forum Newbie / General discussionsReplies: 5Last Post: 27th Dec 2017, 00:32 -
Need to repair Skype Video Call AVI file!
By DWCJedi in forum Newbie / General discussionsReplies: 17Last Post: 12th May 2017, 18:27 -
Repair damaged MKV file
By robnyt in forum DVD RippingReplies: 1Last Post: 25th Dec 2015, 16:53
