Hello,
I have an old action movie (Desert Heat with Van Damme if anyone is wondering lol) on VHS tape that I am trying to watch, however, when the tape plays it shows video and audio fine then fuzzes out with static, cuts out and then comes back on and that happens over and over.
When I fast forward or rewind the tape the picture looks clear throughout,
Also, if I watch to a point where it goes through the fuzz/static process then rewind back past it and let the tape run it doesn't do it in the same place twice.. could there be a tension issue with the tape??
Additionally, I have tried several other VHS tapes in the VCR and they are all working so I don't believe it is a head cleaning issue but I may be wrong.
thoughts, help, direction --THKS
Try to manually adjust the tracking, as johnmeyer suggested. With most late-model VCRs, you can manually adjust tracking while a tape is playing by tapping the up or down channel button on the remote or front panel.
If that doesn't help, you may have edge damage on the actual tape ribbon. This was especially common with commercial movie rental tapes. The damage isn't bad enough to prevent the movie playing completely, but it is bad enough that no VCR can get a steady lock on the tracking (hence the repeated glitching).
Trying the tape in another VCR would tell you for sure: if it plays steady, your own VCR just doesn't "like it" for some reason. If you see the same glitch, the tape itself is probably damaged. You should be able to buy another copy of this movie in better condition for just a couple bucks on eBay.Last edited by orsetto; 16th Oct 2020 at 12:44.
I've got a tape that does this in one particular VCR, it plays fine then slowly rolls with static, then it's fine, then static/rolling again. It plays OK in another VCR.Trying the tape in another VCR would tell you for sure: if it plays steady, your own VCR just doesn't "like it" for some reason.
VHS Tape won't play back - just says "tracking"
By itm2 in forum RestorationReplies: 16Last Post: 22nd Aug 2020, 19:24 -
Repair options for VHS tape with mechanical issue?
By catravingtcinq in forum RestorationReplies: 1Last Post: 10th Jul 2020, 11:29 -
Is this a tracking issue..... or do I need TBC?
By DiggyDre in forum RestorationReplies: 7Last Post: 24th Jan 2019, 18:40 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 08:14 -
VHS tape got stuck in VCR, now VCR plays full static
By Rand251 in forum Newbie / General discussionsReplies: 21Last Post: 4th Apr 2016, 10:40
