JA, that Settop box I showed above records to MPG. It won't play MTS files (samples I got from here, but the WDTV Live HD (model CH3) will. Neither box needs a network or computer to function.
Results 61 to 74 of 74
Aussie HD broadcasts are AVC. They come off my WinTV 8.5 as TS. I think the issue with those MTSs I linked is that they are BDAV. Not an expert though, and not that it's relevant to JA's easily-solved conundrum.
Sorry, you're right, the String SRT 5432 does support h.264. I searched the companies technical specs page for "264" this morning but didn't find it. I must have made a typo or something because, looking again, I see it supports h.264.
https://strong.com.au/HD%20Digital%20Set%20Top%20Box%20with%20Record%20Function%20via%20USB
BDAV is only a minor modification to TS. Have you tried renamingthe files with the TS extension?Profile Level: MPEG-1/2 MP@ML, H.264 DivX & MPEG4 -
@Alwin In N. America there are basic converter boxes with a PVR function available from Mediasonic/Homeworks, Aluratek, and a few other companies that can record TV on a USB stick as unencrypted mts files. As already stated, a model from Mediasonic/Homeworks was recommended to Just Ambivalent earlier in this thread.
There is a significant difference in the selection and capabilities of devices sold for recording OTA TV in N. America and those sold in the rest of the world. For example, TVs that are able to record OTA TV to a USB stick and Blu-ray recorders made for recording OTA TV have never been available here.Last edited by usually_quiet; 18th Oct 2020 at 11:21. Reason: Clarity
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
@JustAmbivalent There is a new Tablo box, the Tablo DUAL LITE OTA DVR with WiFi, for recording OTA TV. This box won't allow you to connect a USB stick directly to the box and export recordings but you can plug a USB stick into your computer and use a third party program (TabloRipper or Tablo Exporter) to pull your videos off of your Tablo and onto your PC as mp4 files. You can subscribe to Tablo's gude service or use broadcast EPG data to schedule recordings as well as set up recordings manually.
According to the Tablo site: https://www.tablotv.com/setup-networking/#harddrive, there's no mention of being able to record on your PC and actual setup is much more complicated, requiring a 1TB+ hard drive* to record and a Smart TV or external media player to watch the recordings.
*The site states that the following aren't supported as storage devices:
- USB Flash Drives (AKA Memory Sticks, AKA USB Keys)
- Network-Attached Storage (NAS)
- Internal drives in external enclosures - HUH? Oh, they mean portable drives which may draw require too much current to operate properly. Not a good sign of quality.
Please provide a link to where it says you can record the signal directly on you PC.
Edit: It just dawned on me. The box is a Chromecast with an ATSC tuner and external hard drive as it's source. Interesting concept. The real questions are, can the hard drive be removed and the contents accessed directly, what format are the files in and are the files encrypted.Last edited by lingyi; 18th Oct 2020 at 16:07.
Google search reported this:
https://github.com/cyclej/TabloRipper/wiki -
I never said anyone could record on their PC using the Tablo. I said someone can connect a USB stick into their computer and use a third party program (TabloRipper or Tablo Exporter) to pull their recordings off of their Tablo and onto their PC as mp4 files. That's similar to what happens when someone uses kmttg to copy non-encrypted recordings from a TiVo to a PC.
The Tablo re-encodes the transport stream as it records and stores recordings as H.264 video and two-channel AAC audio, so creating an mp4 file from those is a very quick and easy process that both TabloRipper or Tablo Exporter are supposed to be able to do.
Yes, the Tablo isn't a media player so you need a compatible streaming media player or smart TV app to watch recordings via streaming from the Tablo.Last edited by usually_quiet; 18th Oct 2020 at 19:17.
Interesting TY!
Edit: Nevermind. I see Alwyn already suggested using a USB tuner in the first reply to the OP and the idea was poo-pooed.Last edited by lingyi; 18th Oct 2020 at 18:29.
Random thought that just dawned on me and may have been poo-pooed by the OP. Since a device like the streams the output to the PC which then streams it to the TV, why bother converting the file? Just stream it or cast it from the PC directly to the second TV, through DLNA, Chromecast or other protocol.
Edit: Thinking about it, all the Tablo is doing is what Alwyn suggested in his first post. A PVR with streaming capabilities that can be easily done with the "crap" (sorry comment realllllly gets my goat and the whole farm!) solution of a DIY PVR. Probably even an Android Box with Kodi could do it. Advantage is you're not locked into any specific hardware and no sneakernet for the files.
I personally am not a fan of streaming, but this seems like a good reason/application.
Edit 2: In case anyone is wondering why I'm still posting. I don't care about the OP, but as always I hope a better/best solution can be found for others. Yeah, I'm grouchy SOB at times!Last edited by lingyi; 18th Oct 2020 at 18:55.
Renaming those MTS to TS worked; they happily play in my Strong set-top box.Originally Posted by Jagabo
Personally, I record with PC TV tuners and a Windows HTPC. My HTPC is connected to a non-smart TV with HDMI. I can use DLNA with my mother's smart TV or file-sharing over my home network with other computers to watch elsewhere at home. I'm not going to pretend my solution was as easy to set up as simply using a TiVo would be but it is less expensive since I used my old PC as an HTPC when I upgraded to newer hardware.
However, totally I understand the appeal of a device designed specifically for recording TV.Ignore list: hello_hello, tried, TechLord, Snoopy329
Recommended < $100 portable digital audio recorder?
By yetanotherlogin in forum AudioReplies: 0Last Post: 18th Aug 2020, 05:00 -
Capturing issues for VHS to DVD/Digital files.
By liberty610 in forum Capturing and VCRReplies: 15Last Post: 26th Jan 2018, 22:29 -
Elgato vs Macbook Air - Elgato Shows It's Capturing Overlays But It's Not
By Damianj321 in forum Capturing and VCRReplies: 0Last Post: 18th Dec 2017, 15:09 -
Portable digital recorder that can accept analog video source
By spapakons in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 25Last Post: 29th Oct 2017, 05:31 -
Review of $28 Walmart Ematic On Air Digital Recorder
By jimdagys in forum DVB / IPTVReplies: 9Last Post: 26th Dec 2015, 19:22
