Hi all
I'm capturing some VHS tapes and noticed in some cases loosing all detail in bright areas. Thought I'd compare how the Panasonic DMR-ES10 compares with a Sony RDR-HXD870 with AGC on/off.
Hope it helps someone:
https://www.youtube.com/watch?v=crEojSrXzFM
Exploring the settings:
https://www.youtube.com/watch?v=XESzXCxf3Hg
Lineage is:
PAL VHS tape (2nd or 3rd gen) --> SONY SLV-D993P --> Sony RDR-HXD870.Panaosnic DMR-ES10 --> Svideo --> JVC Camcorder --> DV (mostly so I could edit with frame accuracy).
Too much video processing and the final nail in the coffin is DV chroma subsampling, not good on my book.
Thanks for the feedback.
I'm not sure what processing you're talking about other than titles and YouTube compression.
As for the DV chroma subsampling, I didn't expect it to be an issue for this but can capture using a different method (let me know what you would suggest). I have a couple of PCIe devices that should do uncompressed yuv/rgb and a couple of hdpvr devices that will do h264 (granted at 4:2:0 yuv I think - about the same as DV?). -
I use the older RDR-HX750 (with hdmi+splitter) , and the Pioneer DVR-440 which has similar hardware a fair bit as a sort-of-TBC. They're a nice alternative to the panasonics with less annoyances, they don't blow out whites in the way the panasonics do and don't turn off the analog (at least s-video/composite) output when it thinks there is no input signal. They're a tad less robust at handling bad tapes than the panasonics, but in most cases they do ok. They've all seemed pretty transparent to me beyond this as long as noise reduction is turned off (I know the NTSC Panasonics have some NR that can't entirely be disabled, but that doesn't seem to be a thing on the PAL ones.)
It's possible to work around the clipping issue on the PAL Panasonic DVRs using a (passive) volume control, potentiometer or similar to lower the video signal level. If lowered below a certain point the AGC "gives up" and doesn't try to push the brights way too far. -
Panasonic DMR ES10 (UK) needs power cord
By Cherbette in forum DVD & Blu-ray RecordersReplies: 18Last Post: 25th Sep 2019, 14:56 -
Panasonic dmr-es10 progressive scan vhs
By tuberlildk in forum Capturing and VCRReplies: 3Last Post: 10th Sep 2019, 08:45 -
Panasonic DMR-ES10 - Broken?
By geordie10 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 9th Jul 2019, 12:49 -
Settings Panasonic DMR-ES10 for pass through
By GovertdeKat in forum Capturing and VCRReplies: 4Last Post: 17th Oct 2018, 12:58 -
Using a Panasonic DMR-ES10 (UK-version) in the Netherlands (pass through)
By GovertdeKat in forum Capturing and VCRReplies: 3Last Post: 13th Dec 2017, 11:50
