    Dec 2007
    Canada
    Is there a way in SubtitleEdit to sync subs visually using many points instead of just two as in the Visual Sync menu item? How is extrapolation before and after end points handled?
    Thanks.
  2. Member Ennio's Avatar
    May 2005
    Netherlands
    Yes, in a way. Select the desired range of sequential lines, rightclick --> Visual sync selected lines
