Hi all,
I am converting VHS to my PC and using Lagarith and plan to convert the 7 videos I have done so far within Virtualdub2 to FFV1. Is YUY2 and YV12 lossless? I heard that RGB is lossy from a Youtube video? How do I get FFV1 maximum compression within Virtualdub2?
				Results 1 to 10 of 10
	You should never capture as RGB. The capture should always be YUY2 or other YUV 4:2:2 arrangement. Lagarith is always lossless if you keep the color format the same. If you convert color format it will not be lossless. The color conversion will cause losses, lagarith will then compress that losslessly.
	Even knowing what format the codec uses doesn't guarantee what you get from a particular decoder. For example NTSC DV is stored internally as YUV 4:1:1 (720x480 luma 180x480 chroma). Most decoders output YUV 4:2:2 (720x480 luma 360x480 chroma). At least one outputs RGB 4:4:4 (720x480 R, G and B).
	Exactly that is my point.
 If I can't be sure of the color format I don't know how best to handle the video.
 I am planning on finally digitizing some home videos and am trying to figure out how best to go about it.
 DV video is a option....
	If you are trying to figure out how to BEST handle the video, follow jagabo's advice if you are starting from Analog sources. If you are starting from already DV sources, just transfer the DV stream, but DV is NOT the "best" option for analog sources, merely a sometimes convenient one.
  How do I forcibly alter the colour range from RGB full to limitedBy bergqvistjl in forum Video ConversionReplies: 2Last Post: 22nd May 2020, 13:45
  Same video converted in Lagarith with only RGB conversion, different resultBy abolibibelot in forum Video ConversionReplies: 21Last Post: 25th Jan 2020, 22:16
  AVS script compression failure in VirtualDub2 / Lagarith RGBBy abolibibelot in forum Video ConversionReplies: 19Last Post: 20th Dec 2018, 03:07
  RGB to YUV to RGBBy chris319 in forum ProgrammingReplies: 70Last Post: 20th Feb 2017, 17:49
  Smart render. Lagarith > Vegas(edit) > Lagarith.By ValentineStone in forum Video ConversionReplies: 11Last Post: 5th Oct 2016, 14:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
