ok Updated potplayer today and The dvd video will no longer show Just black screen.
I know pot player is not user friendly out of box and you need to change specific settings.
I am assuming that is the case.
I can play video files fine but render setting was changed I addressed that.
But I been unable to restore the video and sound for commercial dvd with vob files.
The title is displaying when opening dvd files.
Anyone know which setting it is I need to change to what?
I did not KNOW the correct forum to put it in this is the one that should of been closed to put in the software player forum because this is actually the wrong forum for this question
The people that will know the answer will now not see it. because it is in the wrong place and YOU won't let us move the thread to correct forum when we realize we have it on wrong place.
So move this thread to the correct forum under software player.
To also ask did potplayer remove ability to watch legally owned encrypted comercial dvd that has copy protect? in its most recent update?
I am NOT looking to infringe I just want to watch the movie without the big black bars that are a result of failure for government to force standardization of wide screen format. I like being able to stretch imiage to desired size and shap to fit screen. and can not do this in VLC. -
I just updated Potplayer and tested a copy of DVD rips with no issues. Check your video renderer setting.
And no government anywhere, never had any authority or reason to mandate movie aspect ratios. This was purely an artistic and marketing decision.
Play around with the video aspect settings. I can't tell you what to set, because I don't believe in ruining the correct aspect ratios just to fill my screen.
Lost VirtualDub capture preview after spring 2018 win 10 update
By mtamimi in forum Capturing and VCRReplies: 25Last Post: 23rd Nov 2018, 05:35 -
Manual Update of DAUM PotPlayer Codecs
By c627627 in forum Software PlayingReplies: 3Last Post: 4th Oct 2017, 15:41 -
PotPlayer x64 crashes on Windows 10 Creators Update?
By Wilda in forum Software PlayingReplies: 5Last Post: 20th Jul 2017, 08:18 -
Potplayer, how should I update it?
By Balema in forum Software PlayingReplies: 4Last Post: 2nd Jul 2017, 06:28 -
PotPlayer (64-bit) updated and lost all my settings!!!
By Balema in forum Software PlayingReplies: 10Last Post: 8th Feb 2017, 05:39
