In building a video I pay attention to the % in the left margin of DVDFLICK thinking that once I get close to 100% the video is "full" and I cannot add more video files. I actually bought 8.5GB disks because of this. When I thought I would surpassed the 100% on the left margin of DVDFLICK, I inserted the 8.5GB disk and hit "create DVD" on DVDFLICK. A half hour later I got a message that the video will fit on a standard DVD and I could replace the 8.5Gb disk with a standard one or just proceed. I hit proceed and it created the video just fine. So my question is how do I tell how many video tracks I can add to a DVD when the left margin on DVDFLICK is showing 100%??
I clicked on the update tab and got the message that I am using the latest version. The question I asked was misstated. I guess the real question is what does that % in the left margin mean?
When I try to create the DVD the program actually tells me that I don't need the 8.5Gb disk but I was hoping I could proactively know when I need to stop adding video files. -
The percentage bar is just a rough guide, and I haven't noticed any significant change in its function from v1.3.0.4 thru the current (crowd-sourced) v1.3.10 (over time, I've found v1.3.0.7 to be the most stable, and have retro-graded back to it from later updates).
The percentage indicator bar operates in a fairly binary fashion: if its yellow, you're good to go, if its red, you need a higher capacity blank or need to remove some titles. I usually try to keep around 95%, but theres really no reason to: even maxed out at 100%, I've rarely had a project fail. The worst that ever happens on rare occasions is a dvd template just a trifle too large for the target blank (weirdly, when the bar reads below 100%). If that occurs, I just run it thru DVDshrink to reduce it be 5% with no harm done. -
Thanks. I am satified with the answers to my question. Anyone know how to close this issue out?
Can't align left-center subtitles
By fretta in forum SubtitleReplies: 1Last Post: 27th Nov 2019, 13:53 -
SRT, change vertical margin but keep 1-line subtitles vertically centered
By abolibibelot in forum SubtitleReplies: 15Last Post: 20th Aug 2019, 20:11 -
DVDFlick Subtitles don't display correctly after 8
By dunnel in forum Newbie / General discussionsReplies: 0Last Post: 11th Aug 2018, 14:59 -
How do I set left/right channels with Audacity 2.2.1?
By DSperber in forum EditingReplies: 6Last Post: 18th Feb 2018, 16:02 -
DVDFlick Re-Encoding
By bolintx in forum Authoring (DVD)Replies: 22Last Post: 31st Jan 2016, 16:30
