I was looking at the inexpensive HDMI capture devices on Amazon and saw a BYEASY one. A Youtube reviewer captured video from a Roku Ultra with no HDCP error. Do the cheap Amazon usb devices not have the HDCP encryption issue that Hauppauge has?
Well i guess look further on youtube
HDCP is not the only problem you will encounter with HDMI, there's also the "handshake" problem, you can avoid this with converters, which have the side effect of removing HDCP and disabling the handshake protocoll, but then you have to set the resolution correctly on both sides.
Better search on the gamers websites since they use HDMI on a regular basis, and can give better advice.
The ELGATO CAM LINK in combination with an HDMI audio extractor like the MINI HDMI2HDMI (white casing) could work, search for this on Youtube for use "cases"
HDCP
By Baldrick in forum GlossaryReplies: 7Last Post: 4th Apr 2023, 11:34 -
HDCP problem with Magnavox MDR867H
By Dr DC in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Oct 2017, 19:48 -
HDMI capture without need for hdcp stripper?
By david151 in forum Capturing and VCRReplies: 4Last Post: 15th Oct 2016, 10:42 -
Anyone tried a 4K HDCP with the 1.4 splitter?
By oldfart13 in forum Capturing and VCRReplies: 2Last Post: 3rd Oct 2016, 15:34 -
HDCP Stripping from Xfinity X1
By MikeSD in forum Capturing and VCRReplies: 3Last Post: 5th Nov 2015, 20:54
