I have 30fps video, that is actually just 25fps with duplicates to make it 30fps.
I was wondering if there was a script to restore the original 25fps stream, without any inaccuracy.
There are also dropped frames in this video during fast motion for some reason, they are replaced with dupes. Will these frame drops effect the accuracy of decimation plugins such as tdecimate in mode 2?
	Taking 30 fps with duplicates to 25 fps can be done with AVISynth:
 If, however, you have dups AND dropped frames, that is an entirely different problem and is more difficult to fix. I wrote a script for this situation that I described over at doom9.org:Code:TFM() TDecimate(Cycle=6,CycleR=1)
 Automatically fix dups followed (eventually) by drops
 You need to post 10-15 seconds of he original video, without re-encoding, in order to tell what's really going on.
	Yes. That's what I already said. To say it again, if you only have duplicates, the two-line script will work, and it will work perfectly. If instead you have drops followed by dups, that is something usually caused by a bad capture card or screen capture. If the capture can't keep up, the software drops a frame but then, a few frames later, adds a dup in order to keep the audio in sync.
 It is relatively easy to write software which can find duplicates, but much more difficult to detect where there is a gap left by the missing frame. However, that is what my much more complicated script does.
 Since you refuse to upload a video, you will just have to figure it all out yourself from this point forward.
	I am fine with that, I am not quite sure why there is so much pressure on me to upload the video, i just wanted to ask some questions, i am find with figuring it out by myself, that's how i learn. i respect the privacy of the people in the video and i am not about to post any clips of them over the internet. I'm surprised you guys wouldn't be more understanding.
	You misunderstand. We are strangers who have taken time to help you, but our efforts are not worth anything without being able to see the video. However, since you've made your choice to not allow anyone to see the actual problem you are trying to solve, you probably won't get any more suggestions.
 This isn't anger; it is frustration, although I will admit to being a little peeved at having wasted 5-10 minutes of my life writing my several posts, apparently all for naught.
  Analyze captured AVI for dropped framesBy outhud9 in forum Capturing and VCRReplies: 1Last Post: 2nd Jan 2020, 01:15
  Duplicates Frames. Cause and means?By nji9nji9 in forum RestorationReplies: 51Last Post: 15th Oct 2019, 13:21
  Removing repeated frames from 25fps files on Vevo (originally 23.976)?By digitalfreaknyc in forum Video ConversionReplies: 43Last Post: 24th Jan 2017, 00:55
  Dropped frames upon USB connection eventBy Brad in forum Capturing and VCRReplies: 9Last Post: 4th Jul 2016, 21:03
  Removing Blended frames, then putting unblended duplicates back in??By killerteengohan in forum RestorationReplies: 17Last Post: 16th Oct 2015, 04:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
